RSEG1066 Negotiation Failed [message #1850684] |
Mon, 14 March 2022 06:24  |
Hi all,
I'm quite new on Eclipse and its Remote System Explorer.
I'm trying connecting a remote linux embedded system (supporting Arago distro), but at the end of configuration I get this message:
"Failed to connect sshd on "[ip addr]"
Algorithm negotiation fail
I tried ssh connection directly with commands on terminals, and it work perfectly.
Any suggestions which could be the problem?
Re: RSEG1066 Negotiation Failed [message #1850691 is a reply to message #1850684] |
Mon, 14 March 2022 11:05   |
Andrea Ciullo wrote on Mon, 14 March 2022 10:24
What SSH daemon is running on the remote end? My first guess at a possible cause would be the deprecation of the ssh-rsa SHA1-based signature algorithm.
Modern OpenSSH daemons have it disabled and require the SHA-2 signature algorithms rsa-sha2-256 or rsa-sha2-512.
I think RSE uses the JSch Java SSH library, which does not support rsa-sha2-256 or rsa-sha2-512.
If that is indeed the problem: possible work-arounds or solutions, in increasing order of difficulty, but also increasing likelihood to actually resolve the problem:
- If RSE has a way to use an external SSH executable instead of a Java library, configure it to use that external SSH executable. Otherwise:
- Do not use an RSA key for authentication. Use an ECDSA256 key.
- If that doesn't help, remove a possibly stored RSA host key from ~/.ssh/known_hosts and try again and hope the server offers a non-RSA host key.
- If that still doesn't work, try to use the JSch fork. That fork does implement the SHA-2 RSA signature algorithms. It claims to be a drop-in replacement for JSch 0.1.55, but I don't know if it's OSGi-fied. If not, you many have to re-bundle it.
- Rewrite RSE not to use com.jcraft.jsch at all but org.apache.sshd. That will work for sure (EGit/JGit uses Apache MINA sshd) but it may be (well, will be) a lot of work.
FUDForum. Page generated in 0.08916 seconds
