Home » Modeling » TMF (Xtext) » Installation of older SDK Versions broken(Installation of older SDK Versions broken)
Installation of older SDK Versions broken [message #1850449] Thu, 03 March 2022 07:47 Go to next message
since the release on Monday of 2.26 I'm experiencing that all older SDK-Versions available on the P2-Update-Site are broken.
A clean eclipse installation of 2020-03 is either frozen at the splash screen after installation of 2.23 - 2.25 or throwing a lot of exceptions regarding missing mwe2 plugins.
Did you change anything regarding the older versions in the p2-update sites when releasing 2.26?
Is anybody else experiencing these problems?
Re: Installation of older SDK Versions broken [message #1850452 is a reply to message #1850449] Thu, 03 March 2022 08:08 Go to previous messageGo to next message
i have not seen anything like that. can you provide jstacks? how do you install the older versions?
which mwe and xtext versions end up in the installation?
do you use composite update site or rel specific
https://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.25.0/
[Updated on: Thu, 03 March 2022 08:22] by Moderator
Re: Installation of older SDK Versions broken [message #1850453 is a reply to message #1850452] Thu, 03 March 2022 08:37 Go to previous messageGo to next message
I'm installing the 2020-03 Eclipse IDE for Eclipse Committers using the Oomph Installer and then try to Install XText 2.23 Complete SDK using the "Install new SW" Function within eclipse by adding the XText-Update Page (https://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/).
I added a log and and JStack-Dump from my frozen eclipse. According to the log some of the xtext jars seem not to be available and therefore the eclipse freezes (I guess). But I don't understand why the files are not available anymore as I'm not using a proxy or anything similar that could block the download, so actually it can be just an issue of the update site
  • Attachment: .log
    (Size: 102.83KB, Downloaded 91 times)
  • Attachment: jstack.txt
    (Size: 16.14KB, Downloaded 99 times)
Re: Installation of older SDK Versions broken [message #1850454 is a reply to message #1850453] Thu, 03 March 2022 08:58 Go to previous message
can you please try the non composite update site and add the 2.25 and mwe 2.12.1 update sites individually
and/or select xtext 2.25 & mwe(2) 2.12.1 explicitely
[Updated on: Thu, 03 March 2022 08:59] by Moderator
Previous Topic:Generate correct code in xtend
Next Topic:From custom types to Java types
Current Time: Mon Jul 21 22:31:53 EDT 2025
Powered by FUDForum. Page generated in 0.06536 seconds
