Home » Language IDEs » C / C++ IDE (CDT) » Debugging with GDB - incorrect path to executable
Debugging with GDB - incorrect path to executable [message #1834836] Wed, 18 November 2020 14:32 Go to next message
I've installed Eclipse 2020-09, with Cygwin64 and packages gcc-core 10.2.0-1; gcc-g++ 10.2.0-1. This is on a Windows 10 VM running on MacOS.
I have a very simple helloworld program which compiles and runs in Eclipse, outputting "hello world!" on the console. When I try to debug this, I get a gdb error which I can't fathom:
"failed to execute MI command: -exec-run .... Error creating process: /cygdrive/c/eclipse/C:/Users/andrewjohnson/eclipse-workspace/HelloWorld/C:/Users/andrewjohnson/eclipse-workspace/HelloWorld/Debug/HelloWorld.exe, (error 2)."
Error 2 is a Windows code relating to file not found I believe. Not surprising given that path!
If I run If I run gdb from the command line in the HelloWorld\Debug directory - gdb .\HelloWorld.exe - it works fine and I get "hello world!" output.
I can't work out how Eclipse is building that path to pass to GDB. I do have a Path Mapping set in Source Lookup Path /cydrive/c -> C:\ (although I get that incorrect path generated irrespective).
What's being generated looks like a concatenation of Cygwin_Home, eclipse, CWD or PWD and the project executable. I'm pretty new to this so I've run out of ideas of what to check: it must be a configuration issue with Eclipse that I'm missing so if anyone can help I'd really appreciate it.
thanks
Re: Debugging with GDB - incorrect path to executable [message #1834866 is a reply to message #1834836] Thu, 19 November 2020 06:51 Go to previous messageGo to next message
I downgraded gdb v10.1-1 (sorry, I didn't post that information in the original post) to V8.3.1-1 and it works fine. Obviously Eclipse isn't ready to play with V10 yet.
Re: Debugging with GDB - incorrect path to executable [message #1844432 is a reply to message #1834866] Mon, 13 September 2021 19:39 Go to previous messageGo to next message
9.2-1 worked for me with Cygwin, gdb 10.2 works with MinGW however.
Re: Debugging with GDB - incorrect path to executable [message #1847185 is a reply to message #1834836] Mon, 18 October 2021 10:38 Go to previous messageGo to next message
I can confirm this behaviour.
Eclipse 2021-03 / 4.19 with CDT 10.2.0 does not work with latest cygwin gdb 10.2.0 on
Error in final launch sequence:
Failed to execute MI command:
-exec-run
Error message from debugger back end:
Error creating process /cygdrive/c/ti/ccs1100/ccs/eclipse/C:/Users/r001483/workspace_v11/ccs11_cygwin_managed/C:/Users/r001483/workspace_v11/ccs11_cygwin_managed/Debug/ccs11_cygwin_managed.exe, (error 2).
-exec-run
Its clear why the launch fails - the executable is searched in a path with cygwin and windows parts weirdly intermangled.
Re: Debugging with GDB - incorrect path to executable [message #1847401 is a reply to message #1847185] Mon, 25 October 2021 22:08 Go to previous messageGo to next message
Confirming what Dirk saw; I get the same error, with intermangled paths.
This is on Eclipse 2021-09 RC1 (4.21.0 RC1) with CDT 10.4.0 and Cygwin gdb 10.2-1.
Rolling Cygwin gdb back to 9.2-1 fixes the problem.
-exec-run
Error creating process /cygdrive/c/WINDOWS/system32/C:/Users/David/Desktop/AllProjects/SelectProject/C:/Users/David/Desktop/AllProjects/SelectProject/SelectProject.exe, (error 2).
-exec-run
Re: Debugging with GDB - incorrect path to executable [message #1849589 is a reply to message #1847185] Wed, 26 January 2022 06:36 Go to previous messageGo to next message
Hi Developers,
Nothing works. No solution as above worked except below
I simply replaced gdb with msys gdb
ie. for example
current configuration
... Application Configuration .. Debug .. Debug
GDB Debugger gdb
to
GDB Debugger path to msys gdb (like for example c:\msys\bin\gdb.exe
Re: Debugging with GDB - incorrect path to executable [message #1850349 is a reply to message #1849589] Fri, 25 February 2022 12:47 Go to previous messageGo to next message
I am using arm-linux-gnueabihf-gdb 8.3
and getting error:
-exec-run
Don't know how to run.  Try "help target".
-exec-run
Re: Debugging with GDB - incorrect path to executable [message #1850359 is a reply to message #1850349] Sat, 26 February 2022 13:20 Go to previous messageGo to next message
Are you attempting to use an ARM-Linux native debugger on a Windows machine?
Re: Debugging with GDB - incorrect path to executable [message #1858822 is a reply to message #1850349] Mon, 24 April 2023 15:06 Go to previous messageGo to next message
Hi everyone,
I found a quick and dirty way to fix the issue in my environment eclipse (STM32CubeIDE Version: 1.12.0) and gdb v13.1 on cygwin
The way I fixed it implies the gdb binary recompilation .
I downloaded the latest version (13.1, in test) and modified a specific file before recompiling the binary.
what I changed is the file named windows-nat.c located in the gdb folder (where i uncompress the downloaded tar) : gdb13.1/gdb/windows-nat.c
what I modified in that file is a couple of line : find the following lines :
args = (wchar_t *) alloca ((wcslen (toexec) + wcslen (cygallargs) + 2)
* sizeof (wchar_t));
wcscpy (args, toexec);
wcscat (args, L" ");
wcscat (args, cygallargs);
and make them look like this :
wcscpy (args, wcsstr (toexec, L"Debug"));
// wcscat (args, L" ");
// wcscat (args, cygallargs);
then recompile the binary.
then in eclipse, in the debug configuration configure the debugger to run the newly compiled gdb binary.
Remember, this is a quick and dirty workaround, not a permanent fix.
hope this helps.
Re: Debugging with GDB - incorrect path to executable [message #1860371 is a reply to message #1858822] Tue, 01 August 2023 09:05 Go to previous message
Hubspot partner agency
stock market courses
[Updated on: Thu, 24 August 2023 09:51] by Moderator
Previous Topic:Project-->Properties-->C/C++ General does not appear
Next Topic:Can't run .exe files from eclipse!
Current Time: Mon Jul 21 09:27:04 EDT 2025
Powered by FUDForum. Page generated in 0.05212 seconds
