Home » General (non-technical) » Eclipse Foundation » Installing Software failed
Installing Software failed [message #1850313] Thu, 24 February 2022 20:46 Go to next message
I downloaded linuxtools-docker-4.6.0.zip and wanted to install the plugins in the zip file into eclipse rcp 2020-03.
I followed the installing software wizard in eclipse and it throwed the following error messages:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.rcp, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.fasterxml.jackson.datatype.jackson-datatype-guava,2.9.9.v20190906-1522
No repository found containing: osgi.bundle,com.fasterxml.jackson.jaxrs.jackson-jaxrs-base,2.9.9.v20190906-1522
No repository found containing: osgi.bundle,com.fasterxml.jackson.jaxrs.jackson-jaxrs-json-provider,2.9.9.v20190906-1522
No repository found containing: osgi.bundle,com.github.jnr.constants,0.9.8.v20180207-1730
No repository found containing: osgi.bundle,com.github.jnr.enxio,0.16.0.v20180207-1730
No repository found containing: osgi.bundle,com.github.jnr.ffi,2.1.4.v20180207-1730
No repository found containing: osgi.bundle,com.github.jnr.jffi,1.2.15.v20180207-1730
No repository found containing: osgi.bundle,com.github.jnr.jffi.native,1.2.15.v20180207-1730
No repository found containing: osgi.bundle,com.github.jnr.posix,3.0.35.v20180207-1730
No repository found containing: osgi.bundle,com.github.jnr.unixsocket,0.18.0.v20180207-1730
No repository found containing: osgi.bundle,com.spotify.docker.client,8.11.7.v20180731-1413
No repository found containing: osgi.bundle,com.spotify.docker.client.source,8.11.7.v20180731-1413
No repository found containing: osgi.bundle,javax.ws.rs,2.1.1.v20200204-1659
No repository found containing: osgi.bundle,jnr.x86asm,1.0.2.v201505052040
No repository found containing: osgi.bundle,org.assertj,1.7.1.v20170413-2026
No repository found containing: osgi.bundle,org.eclipse.linuxtools.docker.core.source,4.6.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.docker.docs.source,4.6.0.202003102154
No repository found containing: org.eclipse.update.feature,org.eclipse.linuxtools.docker.editor.ls.feature.source,4.6.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.docker.editor.ls.source,1.0.0.202003102154
No repository found containing: org.eclipse.update.feature,org.eclipse.linuxtools.docker.feature.source,4.6.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.docker.integration.tests.source,2.2.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.docker.reddeer.source,2.2.0.202003102154
No repository found containing: org.eclipse.update.feature,org.eclipse.linuxtools.docker.tests.feature.source,4.6.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.docker.tests.hamcrest-wrap.source,1.2.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.docker.ui.source,4.6.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.docker.ui.tests.source,2.2.0.202003102154
No repository found containing: org.eclipse.update.feature,org.eclipse.linuxtools.jdt.docker.launcher.feature.source,4.6.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.jdt.docker.launcher.source,1.0.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.vagrant.core,2.0.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.vagrant.core.source,2.0.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.vagrant.docs,2.0.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.vagrant.docs.source,2.0.0.202003102154
No repository found containing: org.eclipse.update.feature,org.eclipse.linuxtools.vagrant.feature,4.6.0.202003102154
No repository found containing: org.eclipse.update.feature,org.eclipse.linuxtools.vagrant.feature.source,4.6.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.vagrant.ui,2.0.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.linuxtools.vagrant.ui.source,2.0.0.202003102154
No repository found containing: osgi.bundle,org.eclipse.reddeer.common,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.core,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.direct,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.eclipse,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.jdt.junit,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.jface,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.junit,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.junit.extension,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.requirements,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.swt,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.ui,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.uiforms,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.workbench,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.eclipse.reddeer.workbench.core,2.9.0.v20200306-0847
No repository found containing: osgi.bundle,org.glassfish.hk2.api,2.5.0.v20161103-0227
No repository found containing: osgi.bundle,org.glassfish.hk2.locator,2.5.0.v20161103-0227
No repository found containing: osgi.bundle,org.glassfish.hk2.osgi-resource-locator,2.5.0.v20161103-1916
No repository found containing: osgi.bundle,org.glassfish.hk2.utils,2.5.0.v20160210-1508
No repository found containing: osgi.bundle,org.glassfish.jersey.apache.connector,2.22.1.v20161103-1916
No repository found containing: osgi.bundle,org.glassfish.jersey.bundles.repackaged.jersey-guava,2.22.1.v20161103-1916
No repository found containing: osgi.bundle,org.glassfish.jersey.core.jersey-client,2.22.1.v20161103-1916
No repository found containing: osgi.bundle,org.glassfish.jersey.core.jersey-common,2.22.1.v20181004-1955
No repository found containing: osgi.bundle,org.glassfish.jersey.core.jersey-server,2.22.1.v20181004-1955
No repository found containing: osgi.bundle,org.glassfish.jersey.ext.entityfiltering,2.22.1.v20181004-1955
No repository found containing: osgi.bundle,org.glassfish.jersey.media.jersey-media-json-jackson,2.22.1.v20161117-2005
No repository found containing: osgi.bundle,org.objectweb.asm.analysis,7.2.0.v20191010-1910
No repository found containing: osgi.bundle,org.objectweb.asm.util,7.2.0.v20191010-1910
index.php/fa/41702/0/
index.php/fa/41703/0/
index.php/fa/41704/0/
index.php/fa/41705/0/
Can anyone tell me how to resolve this problem?
Thanks a lot!
  • Attachment: 4.png
    (Size: 30.75KB, Downloaded 668 times)
  • Attachment: 5.png
    (Size: 54.51KB, Downloaded 706 times)
  • Attachment: 6.png
    (Size: 52.41KB, Downloaded 695 times)
  • Attachment: 3.png
    (Size: 98.54KB, Downloaded 721 times)
Re: Installing Software failed [message #1850324 is a reply to message #1850313] Fri, 25 February 2022 01:23 Go to previous messageGo to next message
This latest error is the kind that happens when a site's content metadata and artifact metadata are not in sync with each other. Perhaps Window -> Preferences -> Oomph -> Bundle Pools... -> Clear Cache... will force all the sites to reload such that they are all properly in sync.
Re: Installing Software failed [message #1850328 is a reply to message #1850324] Fri, 25 February 2022 04:15 Go to previous message
It did not work.
Thanks!
Previous Topic:unable to read repository
Next Topic:download plugins for offline desktops
Current Time: Sun Jun 08 21:11:08 EDT 2025
Powered by FUDForum. Page generated in 0.05102 seconds
