Product partial update on latest product version [message #1850248] |
Tue, 22 February 2022 12:48  |
I have a couple of products where I track Eclipse updates (e.g. 2021-06, 2021-09), and, like Eclipse products, I have a "latest" product version.
When I change this product version to a new version, Eclipse is automatically updated.
What I noticed in last upgrade, from 2021-06 to 2021-12, is that EGit plugin was not updated with platform.
Exploring https://download.eclipse.org/releases/2021-12/202112081000 repository, I can check that Git plugin is on version 6.0.0.202111291000-r, but when i check installed Git plugin I get version 5.13.0.202109080827-r. And, if I run a "Check for updates" it brings Git plugin update.
I know that I can put a version range on each of these plugins that comes with default 0.0.0 version range, but this seams odd.
There are any config/setup in my products that I am missing to force this update for all plugins?
Eclipse product setup: https://github.com/trepr/eclipse-setup/blob/main/eclipse-ee-sds-product.setup
Re: Product partial update on latest product version [message #1850276 is a reply to message #1850257] |
Wed, 23 February 2022 10:43   |
Hi, Ed! Thanks!
Quote:check for updates uses more sites than your p2 task
Hum! What I observed, is that old repositories are held after update. For example, in my last update, the repository for 2012-12 was added, but 2012-06 was not removed.
There is a way to remove old repositories? Maybe a task?
Quote:there may well have been things needing the older version
I made some search and found this: https://github.com/tesla/m2eclipse-egit/issues/19
Culprit?
It' a dependency from Jboss Maven Integration.
Quote:In the worst case, you can use bounds to try to force an update.
You mean version range, right?
If my understanding is correct, if I force version I could break above plugin.
So, I think that the solution is to remove this plugin (Jboss Maven Integration) from my product setup, I need to investigate better what we will loose...
[Updated on: Wed, 23 February 2022 10:44] by Moderator
FUDForum. Page generated in 0.06679 seconds
