EclipseLink Validation Exception in Library Eclipse Version 2.7.8 [message #1850202] |
Mon, 21 February 2022 09:34  |
We have created Dynamic Entities and we have a table called Movies.
Movies has following structure
Name Null? Type
ID NOT NULL NUMBER(38)
NAME VARCHAR2(256)
ACTOR VARCHAR2(256)
RATING NUMBER(38)
where ID is the PK to the table Movies
The mappings are set in the dynamic entities using the following code
//Create dynamic class for given object
JPADynamicTypeBuilder dynamicTypeBuilder = createDynamicEntity(entityModel.getEntityName(), dataSource);
//Add column mapping to entity
for (Map.Entry<String, Pair<String, String>> entry : entityModel.getColumnMapping().entrySet()) {
log.debug("Add DirectMapping: field {} and column {}", entry.getKey(), entry.getValue().getKey());
dynamicTypeBuilder.addDirectMapping(
entry.getKey(),
PersistenceConstants.persistenceTypeMap.get(entry.getValue().getValue()),
// Add primaryKey Fields
dynamicTypeBuilder.setPrimaryKeyFields(entityModel.getPrimaryKeys().toArray(
new String[entityModel.getPrimaryKeys().size()]));
// Add created dynamic type to helper :
helper.addTypes(false, false, dynamicTypes);
We had the following code for performing an update operation on a given row.
EntityManager entityManager = customEntityManagerFactory.getEntityManager(dataSource);
try {
entityManager.getTransaction().begin();
entityManager.merge(entity); // entity = {id : 3 name = "harry potter"}
entityManager.getTransaction().commit();
} catch (RuntimeException e) {
e.printStackTrace();
throw new MutationException(String.format("Update entity FAILED for datasource: %s, entity: %s", dataSource,
entity));
customEntityManagerFactory.closeEntityManager(dataSource);
While executing the above function we are experiencing an error with the below stack trace.
Local Exception Stack:
2022-02-21_13:17:29.53994 Exception [EclipseLink-7251] (Eclipse Persistence Services - 2.7.8.v20201217-ecdf3c32c4): org.eclipse.persistence.exceptions.ValidationException
2022-02-21_13:17:29.53994 Exception Description: The attribute [id] of class [com.oracle.graphqlDBforQuerySD.STUDENTS] is mapped to a primary key column in the database. Updates are not allowed.
2022-02-21_13:17:29.53995 at org.eclipse.persistence.exceptions.ValidationException.primaryKeyUpdateDisallowed(ValidationException.java:2553)
2022-02-21_13:17:29.53995 at org.eclipse.persistence.mappings.foundation.AbstractDirectMapping.writeFromObjectIntoRowWithChangeRecord(AbstractDirectMapping.java:1254)
2022-02-21_13:17:29.53995 at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildRowForUpdateWithChangeSet(ObjectBuilder.java:1779)
2022-02-21_13:17:29.53995 at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.updateObjectForWriteWithChangeSet(DatabaseQueryMechanism.java:1045)
2022-02-21_13:17:29.53996 at org.eclipse.persistence.queries.UpdateObjectQuery.executeCommitWithChangeSet(UpdateObjectQuery.java:86)
2022-02-21_13:17:29.53996 at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.executeWriteWithChangeSet(DatabaseQueryMechanism.java:316)
2022-02-21_13:17:29.53997 at org.eclipse.persistence.queries.WriteObjectQuery.executeDatabaseQuery(WriteObjectQuery.java:60)
2022-02-21_13:17:29.53997 at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:911)
2022-02-21_13:17:29.53997 at org.eclipse.persistence.queries.DatabaseQuery.executeInUnitOfWork(DatabaseQuery.java:810)
2022-02-21_13:17:29.53997 at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWorkObjectLevelModifyQuery(ObjectLevelModifyQuery.java:110)
2022-02-21_13:17:29.53998 at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWork(ObjectLevelModifyQuery.java:87)
2022-02-21_13:17:29.53998 at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2983)
2022-02-21_13:17:29.53999 at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1898)
2022-02-21_13:17:29.53999 at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1880)
2022-02-21_13:17:29.53999 at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1830)
2022-02-21_13:17:29.54000 at org.eclipse.persistence.internal.sessions.CommitManager.commitChangedObjectsForClassWithChangeSet(CommitManager.java:275)
2022-02-21_13:17:29.54000 at org.eclipse.persistence.internal.sessions.CommitManager.commitAllObjectsWithChangeSet(CommitManager.java:133)
2022-02-21_13:17:29.54000 at org.eclipse.persistence.internal.sessions.AbstractSession.writeAllObjectsWithChangeSet(AbstractSession.java:4398)
2022-02-21_13:17:29.54000 at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabase(UnitOfWorkImpl.java:1495)
2022-02-21_13:17:29.54001 at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1585)
2022-02-21_13:17:29.54001 at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java:280)
2022-02-21_13:17:29.54001 at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitAndResume(UnitOfWorkImpl.java:1222)
2022-02-21_13:17:29.54001 at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commit(EntityTransactionImpl.java:136)
2022-02-21_13:17:29.54002 at com.oracle.graphql.api.persistence.mutation.MutationExecution.updateEntityExec(MutationExecution.java:117)
2022-02-21_13:17:29.54002 at com.oracle.graphql.api.persistence.mutation.MutationWrapper.updateEntity(MutationWrapper.java:159)
2022-02-21_13:17:29.54003 at com.oracle.graphql.api.resolvers.dbresolver.DatabaseResolverImpl.update(DatabaseResolverImpl.java:271)
2022-02-21_13:17:29.54003 at com.oracle.graphql.api.datafetchers.FetcherRegistration.lambda$getDatabaseUpdateDataFetcher$11(FetcherRegistration.java:991)
2022-02-21_13:17:29.54003 at graphql.execution.ExecutionStrategy.fetchField(ExecutionStrategy.java:279)
2022-02-21_13:17:29.54003 at graphql.execution.ExecutionStrategy.resolveFieldWithInfo(ExecutionStrategy.java:210)
2022-02-21_13:17:29.54003 at graphql.execution.AsyncExecutionStrategy.execute(AsyncExecutionStrategy.java:60)
2022-02-21_13:17:29.54004 at graphql.execution.Execution.executeOperation(Execution.java:159)
2022-02-21_13:17:29.54004 at graphql.execution.Execution.execute(Execution.java:105)
2022-02-21_13:17:29.54004 at graphql.GraphQL.execute(GraphQL.java:613)
2022-02-21_13:17:29.54004 at graphql.GraphQL.parseValidateAndExecute(GraphQL.java:538)
2022-02-21_13:17:29.54005 at graphql.GraphQL.executeAsync(GraphQL.java:502)
2022-02-21_13:17:29.54005 at graphql.GraphQL.executeAsync(GraphQL.java:453)
2022-02-21_13:17:29.54006 at com.oracle.graphql.api.execution.GraphQLExecutorService.execute(GraphQLExecutorService.java:53)
2022-02-21_13:17:29.54006 at com.oracle.graphql.resources.GraphqlResource.invoke(GraphqlResource.java:109)
2022-02-21_13:17:29.54006 at com.oracle.graphql.resources.GraphqlResource.post(GraphqlResource.java:67)
2022-02-21_13:17:29.54006 at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
2022-02-21_13:17:29.54007 at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
2022-02-21_13:17:29.54007 at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
2022-02-21_13:17:29.54007 at java.base/java.lang.reflect.Method.invoke(Method.java:566)
2022-02-21_13:17:29.54007 at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52)
2022-02-21_13:17:29.54008 at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:124)
2022-02-21_13:17:29.54008 at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:167)
2022-02-21_13:17:29.54009 at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ObjectOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:192)
FUDForum. Page generated in 0.05228 seconds
