Home » Language IDEs » C / C++ IDE (CDT) » Activate unused variable warning
Activate unused variable warning [message #1848894] Wed, 22 December 2021 09:01 Go to next message
That should be a very easy one: I just need to see a warning symbol when I declare a variable that is never used. I had a look at
Window -> Preferences -> C/C++ -> Code Analysis
but that problem is not on the list.
Is there any way I could activate that warning? Thanks in advance.
Re: Activate unused variable warning [message #1848938 is a reply to message #1848894] Fri, 24 December 2021 13:49 Go to previous messageGo to next message
There are options under "Potential Programming Problems"
They don't work?
index.php/fa/41495/0/
Re: Activate unused variable warning [message #1848939 is a reply to message #1848938] Fri, 24 December 2021 14:06 Go to previous messageGo to next message
I also thought that "unused variable declaration in file scope" might be the right one, but unfortunately it does not work or at least it does not solve this issue...
Re: Activate unused variable warning [message #1850091 is a reply to message #1848939] Tue, 15 February 2022 09:50 Go to previous message
I am still having this problem and as I said, checking "Unused Variable declaration in file scope" is not the solution. I have seen that one could "customize the problem", but I am using the default settings.
I have even tested with with a hello_world.c adding an unused variable and I did not get any warning from Eclipse. The GCC compiler indeed finds the unused variable as expected.
Previous Topic:plugin development in CDT project
Next Topic:CDT has no SEGGER GDB option
Current Time: Mon Jul 21 04:13:27 EDT 2025
Powered by FUDForum. Page generated in 1.28452 seconds
