Home » Language IDEs » Java Development Tools (JDT) » ClassNotFoundException with runnable jar
ClassNotFoundException with runnable jar [message #1850003] Thu, 10 February 2022 11:53 Go to next message
I made a runnable jar with packed libraries.
I'm going mad with java.lang.ClassNotFoundException: com.mysql.jdbc.Driver
even if I added MySql Connector J in my Java Build Path.
This exception is thrown on a machine with openjdk 11.0.8, while it's not thrown on machines with 1.8.0_302.
When I try to export the runnable jar with libraries inside the lib subfolder, the exception becomes:
java.lang.NoClassDefFoundError: javax/activation/DataSource
Is it not possible to export a runnable JAR from a dev machine with Java 8 and running it on Java 11 ??
Re: ClassNotFoundException with runnable jar [message #1850104 is a reply to message #1850003] Wed, 16 February 2022 01:06 Go to previous messageGo to next message
You said you made a runnable Jar. But didn't specify how you are running. Are you running it from Eclipse or from command line? In either case, can you share what the command looks like?
[Updated on: Wed, 16 February 2022 01:07] by Moderator
Re: ClassNotFoundException with runnable jar [message #1850108 is a reply to message #1850104] Wed, 16 February 2022 03:05 Go to previous message
I solved the problem downgrading OpenJDK from 11 to 8 on the server were the JAR is running.
Regarding your questions:
- I'm running it from command line
- The command looks like "java -jar myapp.jar"
Previous Topic:generalize Eclipse Linux/GTK3 support to Unix/GTK3
Next Topic:WYSIWYG javascript visual designer and layout tools
Current Time: Sat Jul 19 03:14:35 EDT 2025
Powered by FUDForum. Page generated in 0.03933 seconds
