Home » Eclipse Projects » Remote Application Platform (RAP) » RAP Chart - dataset.label(org.eclipse.rap.chartjs to show the indicator)
RAP Chart - dataset.label [message #1849923] Tue, 08 February 2022 10:21 Go to next message
I am using org.eclipse.rap.chartjs as our RAP chart provider.
My question is:
When using Bar chart to show data for every months of 3 years, we'll specify 3 colors for the 3 years, each color represents one year(12 bars), then how to show "labels & years" on the top of the chart?
It usually looks like a small square filled with a color(same as its corresponding bars'), and followed with the year number right side, users can tell which color is which year by "labels & years" indicator.
I know It's like setting "chart.data.datasets[x].label" in Chart.js, I also modified function toJson() in ChartRowData.java, added '.add( "label", "2021")', the "label" can be received by Chart.js, but never shows "labels & years" indicator on the top of chart.
I don't know much of JavaScript.
How can I achieve that?
Thank you!
David Lee
[Updated on: Tue, 08 February 2022 10:25] by Moderator
Re: RAP Chart - dataset.label [message #1849944 is a reply to message #1849923] Wed, 09 February 2022 05:49 Go to previous messageGo to next message
Hi David,
could you please sketch on your screenshot what do want to achieve (where and what label do you want to place).
Ivan
Re: RAP Chart - dataset.label [message #1849945 is a reply to message #1849923] Wed, 09 February 2022 06:04 Go to previous messageGo to next message
Hi David,
just a hint - please check "org/eclipse/rap/chartjs/internal/ChartPaintListener.js" where the chart options from the server are applied to the client widget.
Ivan
Re: RAP Chart - dataset.label [message #1849969 is a reply to message #1849944] Wed, 09 February 2022 21:49 Go to previous messageGo to next message
Hi, Ivan,
Thank you for your reply!
What I need is shown like the attached picture, "color and year number" on the top of the chart.
Best Regards,
David
[Updated on: Wed, 09 February 2022 21:52] by Moderator
Re: RAP Chart - dataset.label [message #1849974 is a reply to message #1849945] Thu, 10 February 2022 01:23 Go to previous messageGo to next message
Ivan Furnadjiev wrote on Wed, 09 February 2022 06:04
Hi David,
Ivan
Hi, Ivan,
Thank you for your hint.
I put 'debugger' in the function handleEvent( event ) {} of "org/eclipse/rap/chartjs/internal/ChartPaintListener.js", the "label" was indeed transferred to dataset.label, but it's not shown on the top of chart!
Did I miss something ?
Best,
David
Re: RAP Chart - dataset.label [message #1849977 is a reply to message #1849974] Thu, 10 February 2022 02:27 Go to previous messageGo to next message
Hi David,
I'm not familiar with client-side Chart.js API. In the "org/eclipse/rap/chartjs/internal/ChartPaintListener.js" you have to pass the label to the correct option/api of the client-side chart widget (if possible).
Ivan
Re: RAP Chart - dataset.label [message #1850044 is a reply to message #1849977] Sat, 12 February 2022 19:12 Go to previous messageGo to next message
Dear Ivan,
Thank you for your replies!
After trying over and over again and looking up related information, my conclusion is:
org.eclipse.rap.chartjs supports Chart.js 1.0 only, which does not support "label"(not "labels") display.
In my opinion, org.eclipse.rap.chartjs is really a simple/good approach to show charts even just supports Chart.js 1.0 only, basically enough for use, the only problem is not showing "label"!
It's a pity!
(If I am wrong, please feel free to let me know!)
Looking forward to seeing its new version if possible!
Best Regards,
David
Re: RAP Chart - dataset.label [message #1851776 is a reply to message #1850044] Fri, 15 April 2022 05:39 Go to previous messageGo to next message
Excuse me Did You discuss about RAP chart from incubator ( https://www.eclipse.org/rap/incubator/ )?
Re: RAP Chart - dataset.label [message #1851785 is a reply to message #1851776] Fri, 15 April 2022 09:34 Go to previous message
Dmitry Dukhov wrote on Fri, 15 April 2022 05:39
Hi, Dmitry,
No.
We discussed about org.eclipse.rap.chartjs which you can download from https://github.com/tbuschto/rap-chartjs not the incubator one on https://git.eclipse.org/c/rap/incubator/org.eclipse.rap.incubator.chart.git
I referred to https://eclipsesource.com/blogs/2014/07/21/yet-another-charting-widget-for-rap/ at first.
David
[Updated on: Fri, 15 April 2022 09:42] by Moderator
Previous Topic:Best practise to dynamically set session language in RAP
Next Topic:Rap e4 UISynchronize
Current Time: Wed Sep 24 20:03:01 EDT 2025
Powered by FUDForum. Page generated in 0.04456 seconds
