Home » Newcomers » Newcomers » Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228(Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228)
Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1848645] Sun, 12 December 2021 00:48 Go to next message
We are using Eclipse 4.19 for our project for building tools. It uses WTP, Egit etc.
It uses org.apache.log4j_1.2.15.v201012070815.jar. We are wondering if the
this version is impacted by the critical Vulnerability announced for Apache Log4J ?
Details: https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-44228
https://www.zdnet.com/article/security-warning-new-zero-day-in-the-log4j-java-library-is-already-being-exploited/
https://www.bleepingcomputer.com/news/security/new-zero-day-exploit-for-log4j-java-library-is-an-enterprise-nightmare/
The maintainers of Apache Log4j have released a new version 2.15.0. yesterday.
Appreciate feedback and insights.
[Updated on: Sun, 12 December 2021 01:09] by Moderator
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1848646 is a reply to message #1848645] Sun, 12 December 2021 02:21 Go to previous messageGo to next message
You can follow this thread for ongoing discussions:
https://www.eclipse.org/lists/cross-project-issues-dev/msg18752.html
The short answer is not to confuse the bundle org.apache.log4j with the bundle org.apache.logging.logj4. The problem is specifically in the latter not the former, and the latter, in the latest release, is used only by org.eclipse.passage.*, so if you don't have that installed you won't have the problematic bundle installed. Note too that it's also not clear that even if you did install passage that it logs content that can be subverted externally.
Using Help -> About -> Installation Details -> Plug-ins and typing org.apache.logging.logj4 in the filter field, you can confirm that you don't have this problematic bundle installed for whatever (older) version of Eclipse you are using...
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1848665 is a reply to message #1848646] Mon, 13 December 2021 09:21 Go to previous messageGo to next message
Thank you Ed for the feedback. Appreciate the same.
Currently we don't have org.apache.logging.logj4. Its only using org.apache.log4j 1-2.15.
Is it fair conclusion that org.apache.log4j 1-2.15 is not impacted by log4shell given its using log4j < 2.x. ?
Any place I can check/discuss plans for upgrading org.apache.log4j 1-2.15 to 2.log4j 2.15 or higher in coming future.
regards
Santosh
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1848671 is a reply to message #1848665] Mon, 13 December 2021 10:54 Go to previous messageGo to next message
As I mentioned in that thread, it's specifically the class org.apache.logging.log4j.core/lookup.JndiLookup that is at fault and neither that class nor even that package is provided by org.apache.log4j but rather by org.apache.logging.log4j. I don't think there is a pressing need to update org.apache.log4j itself, although it's very old. It's provided by the https://www.eclipse.org/orbit/ project which has the https://www.eclipse.org/forums/index.php/f/84/ forum, but it's not very active. You could ask on their mailing list or open a Bugzilla enhancement request...
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1848674 is a reply to message #1848671] Mon, 13 December 2021 11:41 Go to previous messageGo to next message
Thank you Ed for the info. I will take this discussion in Orbit channel.
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1848777 is a reply to message #1848645] Thu, 16 December 2021 08:38 Go to previous messageGo to next message
The problem is that it won't matter wether this plugin includes the functionality or not. Only this relaase number will lead to the rejection of eclipse applications by IT security.
To be able to release commercial software based on eclipse, this bundle needs to be updated!
[Updated on: Thu, 16 December 2021 08:41] by Moderator
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1848778 is a reply to message #1848777] Thu, 16 December 2021 09:02 Go to previous messageGo to next message
When facts don't matter, we've reached an impasse. Not that it matters, but these are the relevant facts for org.apache.log4j_1.2.15
https://www.whitesourcesoftware.com/vulnerability-database/CVE-2019-17571
But if we'd upgraded to what's suggested here two years go we'd, now have the new much more serious problem...
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1848852 is a reply to message #1848778] Tue, 21 December 2021 04:48 Go to previous messageGo to next message
Yes. Facts doesn't matter. Big company security teams wll reject every software include a vulerable log4j - also the old one.
It is not a dead end. The way out is obvious. Eclipse needs to get rid of this way too old library, otherwise the IDE and RCP-based applications will be banned from corporate infrastructures. That's what they say.
[Updated on: Tue, 21 December 2021 05:16] by Moderator
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1848858 is a reply to message #1848852] Tue, 21 December 2021 06:45 Go to previous messageGo to next message
Is what your explaining a fact? If so, does it matter?
Of course Eclipse projects will move forward from this point, but that doesn't happen in a day and it doesn't happen without cost. Are the corporations with infrastructure contributing? Some do, but many don't. That's what we notice.
[Updated on: Tue, 21 December 2021 06:46] by Moderator
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1849775 is a reply to message #1848858] Wed, 02 February 2022 06:04 Go to previous messageGo to next message
It is a fact. I this single case, big OEMs what to get rid of this library. Big OEMs which are member of the eclipse consortium.
What does matter?
Does it matter that this affects years of work of single developers who builded whole software stacks based on eclipse rcp are fucked up because they use eclipse rcp? That's the point here. It's not a matter of funding, but of trust into a whole ecosystem.
This is that urget that it should be easy to get money for that. Nobody asks for money. I have the feeling that the urgency of the problem is not understood at all.
[Updated on: Wed, 02 February 2022 06:57] by Moderator
Re: Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228 [message #1849778 is a reply to message #1849775] Wed, 02 February 2022 08:18 Go to previous message
I would encourage these large OEMs that feel the problem is urgent to come and invest in a solution either by joining the Eclipse IDE working group:
https://ide-wg.eclipse.org/
Or by helping directly the developers and the projects on which the OEMs depend.
You'll see there's quite a bit of discussion about the log4j topic and many actions have been and are being taken:
https://www.eclipse.org/lists/cross-project-issues-dev/2022/Jan/index.html
I think it's the best we can do with the resources available. I would encourage anyone who feels the problem is urgent and that more should be done more quickly, to come and help.
Previous Topic:Paho_MQTTSN
Next Topic:Problem with Papyrus Installer
Current Time: Wed Jul 30 09:32:02 EDT 2025
Powered by FUDForum. Page generated in 0.18166 seconds
