Home » Newcomers » Newcomers » Paho_MQTTSN(Paho_MQTTSN_Broker)
Paho_MQTTSN [message #1849715] Mon, 31 January 2022 00:38 Go to next message
Hi, i try to run this project on PC Win 7, via CygWin, but got this error. Any help ?
https://github.com/eclipse/paho.mqtt-sn.embedded-c
index.php/fa/41607/0/
Re: Paho_MQTTSN [message #1849735 is a reply to message #1849715] Mon, 31 January 2022 10:47 Go to previous messageGo to next message
Your Cmake is not happy as it has not found the C++ compiler on the computer. Did you install the C++ compiler (GNU g++) on Cygwin?
Re: Paho_MQTTSN [message #1849755 is a reply to message #1849735] Tue, 01 February 2022 07:54 Go to previous messageGo to next message
Do you mean to past th mqtt-sn project in to cygwin instalation folder ?
Re: Paho_MQTTSN [message #1849765 is a reply to message #1849755] Tue, 01 February 2022 12:48 Go to previous message
Did you read the error message on the posted screen?
You need to add the path to the compiler to the system PATH given to Cygwin or set the CMake variables as told.
Previous Topic:Birt with XAMPP
Next Topic:Is org.apache.log4j_1.2.15 impacted by critical CVE-2021-44228
Current Time: Wed Jul 30 21:32:02 EDT 2025
Powered by FUDForum. Page generated in 0.12577 seconds
