Home » Language IDEs » C / C++ IDE (CDT) » undefined reference to `log'(<math.h> was included and compilation works for constants but not variables)
undefined reference to `log' [message #1849606] Wed, 26 January 2022 11:50 Go to next message
compiles without issue
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#define TEST 2.0
int main(int argc, char *argv[]) {
	double test = 0.0;
	double result = 0.0;
	test = 2.0;
	result = log(2);
	printf("\nresult is %f", result);
	return 0;
As does this
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#define TEST 2.0
	double test = 0.0;
	test = 2.0;
	result = log(TEST);
	return 0;
BUT this gives an error on compilation
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#define TEST 2.0
	double test = 0.0;
	test = 2.0;
	result = log(test);
	return 0;
The error is shown as :
13:35:39 **** Incremental Build of configuration Debug for project test_fp ****
make all
Building file: ../src/test_fp.c
Invoking: GCC C Compiler
gcc -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"src/test_fp.d" -MT"src/test_fp.o" -o "src/test_fp.o" "../src/test_fp.c"
Finished building: ../src/test_fp.c
Building target: test_fp
Invoking: GCC C Linker
gcc -o "test_fp" ./src/test_fp.o
./src/test_fp.o: In function `main':
/home/jim/projects/test_fp/Debug/../src/test_fp.c:12: undefined reference to `log'
makefile:43: recipe for target 'test_fp' failed
collect2: error: ld returned 1 exit status
make: *** [test_fp] Error 1
"make all" terminated with exit code 2. Build might be incomplete.
13:35:39 Build Failed. 3 errors, 0 warnings. (took 321ms)
The differences in the code are log with constants and log with variable
Interesting that when I use a constant as an argument the reference to "log" is not a problem but when I try using a variable as an argument it can longer find "log".
So far, Googling around, the info has been scanty, but the best I can determine is that the libraries are being linked in the wrong order. This would seem to me to be an error in the makefile generation and that the gcc compiler has gotten more particular with newer releases. I have tried re-compiling older programs that compiled successfully before and that used <math.h>, but now they no longer compile where once they did.
Here is the make file:
# Automatically-generated file. Do not edit!
-include ../makefile.init
RM := rm -rf
# All of the sources participating in the build are defined here
-include sources.mk
-include src/subdir.mk
-include objects.mk
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
endif
-include ../makefile.defs
OPTIONAL_TOOL_DEPS := \
$(wildcard ../makefile.defs) \
$(wildcard ../makefile.init) \
$(wildcard ../makefile.targets) \
BUILD_ARTIFACT_NAME := test_fp
BUILD_ARTIFACT_EXTENSION :=
BUILD_ARTIFACT_PREFIX :=
BUILD_ARTIFACT := $(BUILD_ARTIFACT_PREFIX)$(BUILD_ARTIFACT_NAME)$(if $(BUILD_ARTIFACT_EXTENSION),.$(BUILD_ARTIFACT_EXTENSION),)
# Add inputs and outputs from these tool invocations to the build variables
# All Target
all: main-build
# Main-build Target
main-build: test_fp
# Tool invocations
test_fp: $(OBJS) $(USER_OBJS) makefile objects.mk $(OPTIONAL_TOOL_DEPS)
	@echo 'Building target: $@'
	@echo 'Invoking: GCC C Linker'
	gcc  -o "test_fp" $(OBJS) $(USER_OBJS) $(LIBS)
	@echo 'Finished building target: $@'
	@echo ' '
# Other Targets
clean:
	-$(RM) test_fp
	-@echo ' '
.PHONY: all clean dependents main-build
-include ../makefile.targets
Since the makefile should NOT be edited I am wondering if I am missing something in the initial set-up of my project or is there something else amiss.
My system info:
:~$ cc --version
cc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
I am using Eclipse 2021-12, downloaded directly from eclipse.org
Any information, even just pointing me in the right direction, would be appreciated and likely helpful.
[Updated on: Wed, 26 January 2022 13:30] by Moderator
Re: undefined reference to `log' [message #1849616 is a reply to message #1849606] Wed, 26 January 2022 16:18 Go to previous messageGo to next message
You need to specify the library and path where log can be found.
With managed build it world be under tool settings for the linker.
Re: undefined reference to `log' [message #1849648 is a reply to message #1849616] Thu, 27 January 2022 13:32 Go to previous messageGo to next message
David Vavra wrote on Wed, 26 January 2022 16:18
I believe you misunderstand my issue:
1. the log() function is NOT a user defined function
2. the log() function is part of the standard C library with definitions and info in the math.h header and is part of the environment
3. the <math.h> header file was included in the source file and NOT flagged by the compiler as missing or undefined
4. the log() function worked with constants but NOT variables
Re: undefined reference to `log' [message #1849650 is a reply to message #1849648] Thu, 27 January 2022 13:53 Go to previous messageGo to next message
You are confusing the header file with the library.
The header defines the interface used by the compiler.
It is NOT the library.
You failed to link the library to your program.
I saw no compilation error.
[Updated on: Thu, 27 January 2022 14:01] by Moderator
Re: undefined reference to `log' [message #1849661 is a reply to message #1849650] Fri, 28 January 2022 08:20 Go to previous messageGo to next message
man log says:
LOG(3) Linux Programmer's Manual LOG(3)
NAME
log, logf, logl - natural logarithmic function
SYNOPSIS
#include <math.h>
double log(double x);
float logf(float x);
long double logl(long double x);
Link with -lm.
Re: undefined reference to `log' [message #1849666 is a reply to message #1849661] Fri, 28 January 2022 10:59 Go to previous message
Thank you so much . . . you did point me in the right direction. I found the error of my ways and now the issue is gone.
And I should have known better, I went through the same thing many years ago. I just kept copying and pasting elements from my make files to new make files without thinking about what I was doing.
Now, starting a new project from scratch in a somewhat new IDE I forgot a few things . . . . head-slap
Now it remains to be seen what other things I will forget.
Previous Topic:Searching for Binaries
Next Topic:assembly ide
Current Time: Sun Jul 27 04:43:21 EDT 2025
Powered by FUDForum. Page generated in 0.04818 seconds
