Home » Eclipse Projects » Eclipse Scout » Tile Widget Example(unable to reproduce Tile Widget Demo from git)
Tile Widget Example [message #1849483] Fri, 21 January 2022 03:24 Go to next message
seriously broke my head trying reproduce Tile Widget Demo from git
Form:
public class ExampleForm extends AbstractForm {
	protected int getConfiguredDisplayHint() {
		return IForm.DISPLAY_HINT_VIEW;
	protected String getConfiguredTitle() {
		return TEXTS.get("Product");
	public MainBox getMainBox() {
		return getFieldByClass(MainBox.class);
	public GroupBox getGroupBox() {
		return getFieldByClass(GroupBox.class);
	public TileField getTileField() {
		  return getFieldByClass(TileField.class);
	@Order(1000)
	public class MainBox extends AbstractGroupBox {
		@Order(1000)
		public class GroupBox extends AbstractGroupBox {
			@Order(200)
			public class TileField extends AbstractTileField<TileGrid> {
			        protected boolean getConfiguredLabelVisible() {
					return false;
			        protected int getConfiguredGridW() {
					return FULL_WIDTH;
			       public class TileGrid extends AbstractTileGrid<ICustomTile>{
					protected int getConfiguredGridColumnCount() {
						return 4;
					  public class SimpleTile2 extends AbstractCustomTile {
					  protected String getConfiguredLabel() {
					    return "Tile 2";
				} // public class TileGrid
			}// public class TileField
		}// public class GroupBox
	}// public class MainBox
}//public class ExampleForm
ICustomTile
public interface ICustomTile extends ITile {
  String PROP_LABEL = "label";
  String getLabel();
  void setLabel(String label);
  String getGroup();
  void setGroup(String group);
AbstractCustomTile
public abstract class AbstractCustomTile extends AbstractTile implements ICustomTile {
  private String m_group;
  protected void initConfig() {
    super.initConfig();
    setLabel(getConfiguredLabel());
  protected String getConfiguredDisplayStyle() {
    return DISPLAY_STYLE_DEFAULT;//DISPLAY_STYLE_PLAIN;
  @ConfigProperty(ConfigProperty.TEXT)
  @Order(10)
    return null;
  public String getLabel() {
    return propertySupport.getPropertyString(PROP_LABEL);
  public void setLabel(String label) {
    propertySupport.setProperty(PROP_LABEL, label);
  public String getGroup() {
    return m_group;
  public void setGroup(String group) {
    m_group = group;
the only change - in getConfiguredDisplayStyle - if I set DISPLAY_STYLE_PLAIN, then the tiles are not visible at all. With DISPLAY_STYLE_DEFAULT - tiles visible, but they are empty
|______| not |_Tile 2__| as in Scout widgets demo
what am I doing wrong?
Re: Tile Widget Example [message #1849496 is a reply to message #1849483] Fri, 21 January 2022 12:01 Go to previous messageGo to next message
Hi Oleg,
you need to define how the content should be displayed: https://github.com/bsi-software/org.eclipse.scout.docs/tree/releases/11.0/code/widgets/org.eclipse.scout.widgets.ui.html/src/main/js/tile. Don't forget to register these files in the index-files.
If you don't want to write any JavaScript code you could use IHtmlTile instead.
Best regards
Claudio
Re: Tile Widget Example [message #1849528 is a reply to message #1849496] Mon, 24 January 2022 00:46 Go to previous messageGo to next message
Thank you very much, Claudio, it worked with IHtmlTile (and with FormFieldTile with any fields on it too).
I look at js on git, however, can I read somewhere more about js files and their construction /use in this case (and maybe in other situations, for the future)? I didn't find a description of working with js (*.ui.html) anywhere in the documentation. Probably not looking in the right place.
Re: Tile Widget Example [message #1849530 is a reply to message #1849528] Mon, 24 January 2022 03:01 Go to previous messageGo to next message
Hi Oleg,
you will find the documentation of the JavaScript part in the Scout JS technical guide.
Re: Tile Widget Example [message #1849532 is a reply to message #1849528] Mon, 24 January 2022 03:06 Go to previous messageGo to next message
I added *.js from git\org.eclipse.scout.widgets.ui.html/src/main/js/tile/ to my example _.ui.html/src/main/js/tile/
in index.js add
export {default as CustomTile} from './tile/CustomTile';
export {default as CustomTileAdapter} from './tile/CustomTileAdapter';
in index.less add
@import "tile/CustomTile";
without any success. I would like, of course, to understand why, but I will not distract you further with this question. Got out of the situation with AbstractFormFieldTile. Everything is fine with him, except for one thing.
I build my tile using the AbstractGroupBox class, where I add everything I need. The only thing, initially, when adding a tile programmatically, I have to refer to:
public static class SimpleTile extends AbstractFormFieldTile<AbstractSlideMainBox>{
	// AbstractSlideMainBox is my GroupBox Class
	public void setSlideName(String slideName) {
		getTileWidget().setLabel(slideName);
	public void SetImageFromURL(String slideURL) {
		getTileWidget().SetImageFromURL(slideURL);
	// and here is the most interesting thing, what I would like to avoid
	@Order(10)
	public class SlideField extends AbstractSlideMainBox {
This last public class SlideField extends AbstractSlideMainBox{} leads to the appearance :
WARN [scout-model-thread-22 Transforming response to JSON] org.eclipse.scout.rt.client.ui.form.fields.AbstractFormField.classId(AbstractFormField.java:1183) - Found a duplicate classid for SlideField_org.eclipse.scout....ExampleForm, adding field index. Override classId for dynamically injected fields.
as many times as tiles i add. actually, it's understandable why . But would like to know, how to add SlideField to FormFieldTile differently to avoid these warnings.
Something like:
getTileWidget().addField(new AbstractSlideMainBox());
Re: Tile Widget Example [message #1849599 is a reply to message #1849532] Wed, 26 January 2022 09:15 Go to previous message
Actually, I had to do without dynamic generation of tiles, and create them in the tilegrid and fill in and hide the extra ones when initializing the form. The option suits me with classic java.
Previous Topic:Problem with running application, Scout 10
Next Topic:DISPLAY_STYLE_BENCH
Current Time: Sun Jul 20 21:20:27 EDT 2025
Powered by FUDForum. Page generated in 0.08415 seconds
