Home » Eclipse Projects » Eclipse Platform » Problems Debugging GUI Application.
Problems Debugging GUI Application. [message #184930] Mon, 26 January 2004 10:05 Go to next message
Originally posted by: brian.sue.embarcadero.com
I've just installed Eclipse 3.0M6 and I'm finding problems while debugging.
I'm trying to remote debug a GUI application and at certain spots both
applications (Eclipse and the app that I'm debugging) seem to hang. When I
stop the debugger then both apps continue normally.
I just upgraded from 3.0M3 where I was using the same setup, and everything
worked fine.
I'm just wondering if anybody else has experienced this problem and if so,
how do you get around it?
I'm running Eclipse on Windows XP SP1 on a P4 2.4 GHz and 1 GB of RAM.
Thanks in advance,
Brian.
Re: Problems Debugging GUI Application. [message #185401 is a reply to message #184930] Tue, 27 January 2004 08:47 Go to previous messageGo to next message
This sounds like a problem we have not seen. A bug report with a
reproduceable test case would be a good place to start.
Darin
"Brian" <brian.sue@embarcadero.com> wrote in message
news:bv3a87$37n$1@eclipse.org...
debugging.
I
everything
> worked fine.
> Thanks in advance,
> Brian.
Re: Problems Debugging GUI Application. [message #185600 is a reply to message #184930] Tue, 27 January 2004 13:05 Go to previous message
> worked fine.
To me this happens (under Linux-GTK) if I paste text inside the target
application and the clipboard content was copied from the target
application as well. Never seen it on Windows, though.
-tom
Previous Topic:KeyListener
Next Topic:metrics mixup
Current Time: Sat Jul 19 09:36:49 EDT 2025
Powered by FUDForum. Page generated in 0.04425 seconds
