Home » Eclipse Projects » Kura » IntelliJ IDEA support
IntelliJ IDEA support [message #1849219] Sun, 09 January 2022 04:01 Go to next message
Hi All,
anybody here tried to build and use the IntelliJ IDEA IDE for KURA development? We are going to build some additional devices and cloud connections but prefer to stay with our common IJ environment. I know that maybe that's approach isn't fully compliant with the whole Eclipse community.
Re: IntelliJ IDEA support [message #1849224 is a reply to message #1849219] Sun, 09 January 2022 11:10 Go to previous messageGo to next message
I have no direct info about IntelliJ usage. In the Kura development team we are all using the Eclipse IDE.
The only potential issue that I see is that the Eclipse Kura build system uses Eclipse Tycho, that is interpreted by the Eclipse IDE but may not be fully understood by IntelliJ.
Matteo
Re: IntelliJ IDEA support [message #1849228 is a reply to message #1849224] Sun, 09 January 2022 13:08 Go to previous messageGo to next message
thank you, hoped only if there is some proved path to make it possible. In that case we will try to use Eclipse IDE ... btw for sure will be coming back with some ideas and improvements as we see to use Kura as the main SW stack at our IoT smart energy HW platform.
Cheers
Tomasz
[Updated on: Sun, 09 January 2022 14:52] by Moderator
Re: IntelliJ IDEA support [message #1849264 is a reply to message #1849228] Mon, 10 January 2022 10:36 Go to previous message
It would be great if you could contribute your findings!
Matteo
Previous Topic:custom topic
Next Topic:BLE disableValueNotifications does not remove callbacks
Current Time: Sun Jul 20 21:27:53 EDT 2025
Powered by FUDForum. Page generated in 0.04318 seconds
