Home » Archived » Jubula » Embedded agent test with API: Application won´t start
Embedded agent test with API: Application won´t start [message #1849149] Wed, 05 January 2022 07:23 Go to next message
Hi all,
I have been using an external AUT agent and starting my application in this way (which works fine by the way):
    public void setup() {
        AUTAgent autAgent = MakeR.createAUTAgent(_host, _port);
        autAgent.connect();
        AUTConfiguration config = new SwingAUTConfiguration( //
                _name, //
                _autId, //
                _command, //
                _workingDir, //
                null); //
        AUTIdentifier identifier = autAgent.startAUT(config);
        if (identifier != null) {
            AUT aut = autAgent.getAUT(identifier, SwingComponents.getToolkitInformation());
            aut.connect();
            _jubulaResources = new JubulaResources(autAgent, aut, identifier);
For various resons I would like to use the embedded AUT agent instead. I have changed my code according to the exmples i have found and it looks like this.
        AUTAgent autAgent = Embedded.INSTANCE.agent();
        autAgent.connect();
                _name, //
                _autId, //
                _command, //
                _workingDir, //
                null); //
            aut.connect();
As you can see the only difference between the two is the first line of each method.
When using the embedded variant the call AUTIdentifier identifier = autAgent.startAUT(config); returns null and my application won´t start.
Tracing the calls it seems as the variable genericStartResponse is set to 4 which equals to AutStartResponse.DATA. Code snippet below is from AUTAgentImpl.startAUT() method.
            m_agent.send(startAUTMessage);
            Object genericStartResponse = Synchronizer.instance()
                .exchange(null);
            if (genericStartResponse instanceof Integer) {
                int startResponse = (Integer) genericStartResponse;
                return handleResponse(startResponse);
What am I missing here? Anybody have any input?
Kind regards,
Martin J
Jubula 8.8.0.034
OpenJDK 17
[Updated on: Wed, 05 January 2022 07:27] by Moderator
Re: Embedded agent test with API: Application won´t start [message #1849180 is a reply to message #1849149] Thu, 06 January 2022 07:28 Go to previous messageGo to next message
Can you please check if you added all necessary plugins to your project [1]
best regards
Marvin
[1] https://help.eclipse.org/2020-12/topic/org.eclipse.jubula.client.ua.help/content/html/developerManual/clientAPI/ch02s08s03.html
Re: Embedded agent test with API: Application won´t start [message #1849238 is a reply to message #1849180] Mon, 10 January 2022 02:43 Go to previous messageGo to next message
Hi Marvin,
I suppose you mean this link? https://help.eclipse.org/2020-12/topic/org.eclipse.jubula.client.ua.help/content/html/developerManual/clientAPI/ch02s08s01.html
I am using gradle and my build.gadle file looks like this:
apply plugin: 'java-library'
dependencies {
    api ':javax.xml'
    api ':ch.qos.logback.classic'
    api ':ch.qos.logback.core'
    api ':javax.xml.stream'
    api ':org.slf4j.api'
    api ':org.xmlpull'
    api ':com.thoughtworks.xstream'
    api ':org.apache.commons.beanutils'
    api ':org.apache.commons.codec'
    api ':org.apache.commons.exec'
    api ':org.apache.commons.io'
    api ':org.apache.commons.lang'
    api ':org.apache.oro'
    api ':org.eclipse.jubula.autagent.api'
    api ':org.eclipse.jubula.autagent.common'
    api ':org.eclipse.jubula.client.api.commands'
    api ':org.eclipse.jubula.client.api'
    api ':org.eclipse.jubula.communication'
    api ':org.eclipse.jubula.rc.common.agent'
    api ':org.eclipse.jubula.rc.common'
    api ':org.eclipse.jubula.rc.swing'
    api ':org.eclipse.jubula.toolkit.api'
    api ':org.eclipse.jubula.toolkit.base.api'
    api ':org.eclipse.jubula.toolkit.concrete.api'
    api ':org.eclipse.jubula.toolkit.swing.api'
    api ':org.eclipse.jubula.tools'
    api ':org.eclipse.jubula.tools.exec'
    api ':org.eclipse.osgi'
I have doublechecked and it seems as I have all the libraries that is listed in the supplied link. The jar-files have been copied from the jubula_8.8.0.034\development\api\JARs folder of the Jubula installation.
Kind regards,
Martin
Re: Embedded agent test with API: Application won´t start [message #1849407 is a reply to message #1849238] Tue, 18 January 2022 03:47 Go to previous messageGo to next message
Hi again Marvin,
Was there any particular plugin that you suspected were missing?
I could still need some help with this issue.
What does AutStartResponse.DATA mean?
Kind regards,
Martin
Re: Embedded agent test with API: Application won´t start [message #1851206 is a reply to message #1849407] Wed, 30 March 2022 09:55 Go to previous message
I found a solution to my problem. It seems the instruction found here: https://help.eclipse.org/2020-12/topic/org.eclipse.jubula.client.ua.help/content/html/developerManual/clientAPI/ch02s08s01.html is faulty.
I reverted back to trying to get the SimpleAdder example working and found this: https://git.eclipse.org/c/jubula/org.eclipse.jubula.core.git/tree/org.eclipse.jubula.examples.api.swing/README.md. This instruction says "all development jars for the API({JUBULA}/development/api/JARs/) must be copied into the "libs" folder". When I did so I got the embedded autagent to work.
Martin
Previous Topic:Database error after install
Next Topic:Check clipboard value
Current Time: Sat Sep 13 03:43:42 EDT 2025
Powered by FUDForum. Page generated in 0.38923 seconds
