Home » Eclipse Projects » Remote Application Platform (RAP) » How to send data from JS to Java?
How to send data from JS to Java? [message #1848560] Tue, 07 December 2021 18:05 Go to next message
I followed https://eclipsesource.com/blogs/2010/12/18/a-new-google-maps-widget-for-swt-and-rap/
, it works very well without using RemoteObject!
As "You simply call JavaScript from Java and vice versa!" stated on the article ,
I tried to send latitude/longitude data from GMap.js to GMap.java by adding the following code in GMap.js.
window.getCurrentPosition = function() {
navigator.geolocation.getCurrentPosition(position => {
const { latitude, longitude } = position.coords; // successfully get latitude/longitude
// pack data in JSON form.
var jsonStr = '{"latitude":' + latitude.toString() + ', ' + '"longitude":' + longitude.toString() + '}';
const jsonCenter = JSON.parse(jsonStr);
return jsonCenter; // send back to RAP
Calling the function above from GMap.java with no error, but cannot get the return value, always gets null on Java side.
How can I achieve that?
Thank you so much!
David
[Updated on: Sun, 16 January 2022 20:52] by Moderator
Re: How to send data from JS to Java? [message #1849147 is a reply to message #1848560] Wed, 05 January 2022 07:00 Go to previous messageGo to next message
how do you call this function from the server? Is it possible to provide a complete example.
Ivan
Re: How to send data from JS to Java? [message #1849376 is a reply to message #1849147] Fri, 14 January 2022 11:39 Go to previous messageGo to next message
Hi, Ivan,
I don't know much of JavaScript, completely followed and based on Mr. Tim Buschtöns's example.
I finally changed it as below.
JavaScript:
window.currentlatlng = '';
let latlng = latitude.toString() + ', ' + longitude.toString();
window.currentlatlng = latlng;});
window.getCurrentLatLng = function() {
return window.currentlatlng;
Java:
browser.evaluate( "getCurrentPosition()" );
String currentLatLng = (String) browser.evaluate( "return getCurrentLatLng()" ); // successfully gets value
BTW, another question is the error as following.
for example:
const { latitude, longitude } = position.coords; // OK
window.geocoder = new google.maps.Geocoder(); // error here
How to access GMap API like 'new google.maps.Geocoder()' inside navigator.geolocation.getCurrentPosition() function?
Thank you and have a nice day.
David
[Updated on: Sun, 16 January 2022 21:48] by Moderator
Re: How to send data from JS to Java? [message #1856192 is a reply to message #1849376] Fri, 25 November 2022 06:13 Go to previous messageGo to next message
you should implement a BrowserCallback in your browser.evaluate
https://download.eclipse.org/rt/rap/doc/3.22/guide/reference/api/org/eclipse/swt/browser/Browser.html#evaluate(java.lang.String,org.eclipse.rap.rwt.widgets.BrowserCallback)
And your getCurrentPosition() should return a String rather than a Json.
In your callback, evaluationSucceeded handles the return of "getCurrentPosition()" as Object.
Cast the result if instance of String and parse it.
Regards.
Re: How to send data from JS to Java? [message #1856197 is a reply to message #1856192] Fri, 25 November 2022 17:21 Go to previous message
Hi, Julien
Thank you for your answer!
David
Previous Topic:Menu issues
Next Topic: Remote Object - instant variable transmittion of both sides?
Current Time: Mon Jul 21 02:05:38 EDT 2025
Powered by FUDForum. Page generated in 0.09107 seconds
