Home » Language IDEs » Java Development Tools (JDT) » Suddenly all breakpoints silently fail
Suddenly all breakpoints silently fail [message #1849021] Wed, 29 December 2021 12:42 Go to next message
My Java 11 Eclipse 4.22 installation has happily supported Java debugging for many days.
Suddenly breakpoints are no longer shown as a blob, rather a diagonal (deprecated/not-installed) line is drawn through them all, even on a trivial independent Java project, Nothing distinctive is visible in the error log. No clues in the Breakpoint Properties.
Restarting/rebuilding/rebooting/moving to 4.21 makes no difference. (A different installation + workspace is still fine.)
But when restarting, the breakpoints are correctly shown as a blob until a JUnit launch (standalone or plugin) is activated. Then they all re-acquire a diagonal line.
It is possible that the failure started after I closed about 30 projects, or perhaps after I obsoleted a .settings/org.eclipse.jdt.ui.prefs. Closing the projects upset the advanced source lookup error log-wise, but reopening hasn't helped.
Any suggestions as to how to get breakpoints to work again?
Ed Willink
Re: Suddenly all breakpoints silently fail [message #1849039 is a reply to message #1849021] Thu, 30 December 2021 08:00 Go to previous messageGo to next message
Can you attach the image?
Have you added a trigger breakpoint by mistake?
Re: Suddenly all breakpoints silently fail [message #1849045 is a reply to message #1849039] Thu, 30 December 2021 11:40 Go to previous messageGo to next message
Sounds like you accidentally toggled the Breakpoints View's toolbar button to Skip All Breakpoints.
Re: Suddenly all breakpoints silently fail [message #1849050 is a reply to message #1849045] Thu, 30 December 2021 14:35 Go to previous message
Thanks. Spot on. What a truly and incredibly bad ergonomic.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=578000 raised identifying six opportunities that JDT fails to take to rescue the user from the nightmare.
Ed Willink
Previous Topic:No repository found at https://download.eclipse.org/eclipse/updates/4.21-P-builds/.
Next Topic:The packagexxx is accessible from more than one module: <unnamed>
Current Time: Sun Nov 02 19:55:47 EST 2025
Powered by FUDForum. Page generated in 0.20107 seconds
