Help- "Map to" option not displayed [message #1848949] |
Sun, 26 December 2021 11:30  |
Hello , I have an issue with hardware mapping, I am trying to map some FBs with the devices I have connected in my system configuration. The problem is I created the project and its application and I have made all the connections and when I hit right click, the "Map to" option does not appear. The strange thing is that I have a complete project loaded through when I downloaded the software and there right click works just fine, displaying hardware mapping normally. Can you help me? I am trying to map my FBs to the devices I want them to run and can't find a way to do so.
I have the 1.6.1 version of 4diac.
[Updated on: Mon, 27 December 2021 03:35] by Moderator
Re: Help- "Map to" option not displayed [message #1849160 is a reply to message #1849148] |
Wed, 05 January 2022 13:55   |
I don't why it is not clear but I'll be more specific. I want to input 2 numbers, don't really care if it happens at the same time or not, and then add them, let's assume I want to input them at the same time . I seem to not be able to understand what happens AFTER I map my two IN_ANYs with the publish_2 (for the PC.PANEL_RESOURCE) . How to I map the subscribe_2 block with my OUT_ANY block after that?
Similar question for the MICROCONTROLLER.EMB_RES, I think I understood how to connect the subsribe_2 with my FB_ADD_INT (through the RD_1,RD_2 and using int2int) on the two inputs of the FB_ADD_INT, but what happens then? Do I use a publish_2? how do I connect its inputs with the single output of the FB_ADD_INT?
I tried my best to explain my problem, I can't seem to find how to solve it, any help would be much appreciated.
Thank you very much Alois!
[Updated on: Wed, 05 January 2022 13:57] by Moderator
Re: Help- "Map to" option not displayed [message #1849161 is a reply to message #1849160] |
Wed, 05 January 2022 14:06  |
The problem is that I don't know your exact task for your exercise and how you solved it so far.
But from your explanation I think I understood more: why do you have 2 OUT_ANYs even if you have two inputs for the two values to add your result is just one value or have I missed something?
FUDForum. Page generated in 0.05033 seconds
