Home » Language IDEs » Java Development Tools (JDT) » Error: Could not find or load main class sun.applet.AppletViewer(Create an applet program with Eclipse)
Error: Could not find or load main class sun.applet.AppletViewer [message #1848954] Sun, 26 December 2021 16:10 Go to next message
Hello evrybody, i have to create an applet program using Eclipse
I m using linux :
Version: 2021-09 (4.21.0)
Build id: 20210910-1417
So i create a project :
I use an execution environnement jre : JAVASE-1.8
and i leave all option
New i create a class :
i leave evrything empty :
import java.applet.Applet;
public class myApplet extends Applet {
		// TODO Auto-generated method stub
and when i lunch my program :
i got this error :
Caused by: java.lang.ClassNotFoundException: sun.applet.AppletViewer
do u know how to fix this error please ?
i can lunch my applet in command line and works with this :
to compile i use this line :
javac --release 8 HelloWorldApplet.java
and i lunch it like this :
appletviewer index.html
but on eclipse not working
in commadn line i can lunch the applet with :
java -version
openjdk version "11.0.13" 2021-10-19
OpenJDK Runtime Environment (build 11.0.13+8-Ubuntu-0ubuntu1.21.10)
OpenJDK 64-Bit Server VM (build 11.0.13+8-Ubuntu-0ubuntu1.21.10, mixed mode, sharing)
if someone can explain me how do the same in eclipse please
thanks
Re: Error: Could not find or load main class sun.applet.AppletViewer [message #1848957 is a reply to message #1848954] Sun, 26 December 2021 23:47 Go to previous messageGo to next message
If there is no special need to use "java.applet.Applet" then I suggest stop trying using it.
Based on https://docs.oracle.com/en/java/javase/17/docs/api/java.desktop/java/applet/Applet.html
this class is deprecated, for removal: This API element is subject to removal in a future version.
Regards.
Re: Error: Could not find or load main class sun.applet.AppletViewer [message #1848958 is a reply to message #1848957] Mon, 27 December 2021 00:04 Go to previous messageGo to next message
Hello again....
Found this:
https://stackoverflow.com/questions/54505959/error-could-not-find-or-load-main-class-sun-applet-appletviewer
Re: Error: Could not find or load main class sun.applet.AppletViewer [message #1848960 is a reply to message #1848958] Mon, 27 December 2021 04:02 Go to previous messageGo to next message
well i see applet, is abandoned by java !
but in university we need to works with this old techno
so to solve my problem i download Kepler eclipse and now works perfectly
the professor told us to use eclipse and forget to tell us about this problem !!!!
well solved with an old eclipse version, for my project i will used Eclipse Kepler
to download old eclipse is here : https://www.eclipse.org/downloads/packages/release/kepler
Re: Error: Could not find or load main class sun.applet.AppletViewer [message #1848965 is a reply to message #1848960] Mon, 27 December 2021 05:24 Go to previous messageGo to next message
Kepler is not just old, it is really really old. Possibly not even supporting Java 9.
As a student you really should be using current technology, in particular Java >= 11. Your future employer will not be impressed if you extol the virtues of Kepler.
As a favor to your colleagues and successors, I suggest That you prod your professor to move out of the dark ages.
Ed Willink
Re: Error: Could not find or load main class sun.applet.AppletViewer [message #1849509 is a reply to message #1848958] Sat, 22 January 2022 02:28 Go to previous message
Got this. Thank you
Previous Topic:Behaviour of @MetaInfServices annotation
Next Topic:Tools for Oracle WebLogic server
Current Time: Tue Aug 12 10:32:22 EDT 2025
Powered by FUDForum. Page generated in 0.04650 seconds
