Home » Modeling » QVT-OML » how to transform a bidirectional relationship?
how to transform a bidirectional relationship? [message #1848906] Wed, 22 December 2021 17:54 Go to next message
I am still a beginner in using QVT for M2M transformation, I wonder if we can transform a bidirectional relation to a class with the QVTo and how?
More precisely, I want to make a transformation from a multidimensional model to a graph model, I had no problem to transform the components of the source model except for the R3:
R1: each fact and dimension are transformed into vertex .
R2: measures, parameter and weak attribute are transformed into vertex property.
R3: the relation between the fact and the dimension is transformed into edge, connecting two vertexes, a vertexIn represents a fact, and vertexOut represents the dimension, with a label named "fact_Dim_Link".
the problem that arises is the transformation of the bidirectional relation that links a fact with a dimension to an edge, I don't know how to describe it in QVTo, knowing that the mapping requires two entities and not a relation.
Thank .
Re: how to transform a bidirectional relationship? [message #1848925 is a reply to message #1848906] Thu, 23 December 2021 14:19 Go to previous messageGo to next message
it is probably easiest to just treat the bidirectional reference as unidirectional in the most convenient direction. The magic of EMF will automatically maintain the opposite direction for free. If you try to do both yourself you invite all sorts of complications.
Ed Willink
[Updated on: Thu, 23 December 2021 14:19] by Moderator
Re: how to transform a bidirectional relationship? [message #1849019 is a reply to message #1848925] Wed, 29 December 2021 12:16 Go to previous messageGo to next message
Hi Ed,
thank you for your feedback, but even if I change this relationship, how to transform the properties of a relationship to another relationship properties. I am lost on this point, most of the articles make transformations of a class towards another, but this point, I found nothing.
In attachment, my two metamodels source and target.
I made all the transformations, and I initialized my MetaModele for the test, the error on the vertexIn and the vertexOut is reported, it asks me that I must define them, knowing that the vertexIn and vertexout describe the relation between a fact and dimension in the source model, Can someone clarify me on this point, how I can realize this transformation.
Doha
  • Attachment: MD_SCTRG.png
    (Size: 327.65KB, Downloaded 159 times)
Re: how to transform a bidirectional relationship? [message #1849024 is a reply to message #1849019] Wed, 29 December 2021 15:08 Go to previous message
HI
Your failure to provide any clue as to what your transformation does leaves me guessing. See https://wiki.eclipse.org/OCL/ForumNetiquette
You target metamodel has no bidirectional relationships so my answer for the harder to-bidirectional use case is not that helpful. The from-bidirectional use case can be trivial unless you overthink it.
If you want to transform the bidirectional L+R, you may use one mapping for L+RtoLA2RA and another for L+RtoRB2LB. You may choose to inline as parts of LtoLA and RtoRB.
A difficulty only arises if you try to re-use an L+RtoLdash+Rdash to produce two unidirectionals from a bidirectional. Returning a tuple of the two is clumsy. Invoking twice will not work since the duplication is optimized away; you have to add a gratuitous disambiguating Boolean parameter so that forward/reverse are distinct mapping invocations.
Obviously if you want vertexIn/vertexOut to feature then they need them to be part of the transformation and you have declined to show your best attempt and so prevented me from providing a better answer.
Ed Willink
Previous Topic:When to use . and ->
Next Topic:Can black-box library use metamodel from workspace?
Current Time: Mon Jul 21 04:14:57 EDT 2025
Powered by FUDForum. Page generated in 0.09326 seconds
