Home » Language IDEs » C / C++ IDE (CDT) » How to static link with mingw x64 C++ runtime and openssl?(Adding the -static flag throws a bunch of linker errors)
How to static link with mingw x64 C++ runtime and openssl? [message #1848823] Sat, 18 December 2021 10:43 Go to next message
I have this small https client thant compiles and links OK with Eclipse CDT , mingw x64 and openssl 1.1.1, so far so good.
In order to run the EXE in another PC I need to distribute the EXE with these DLLs, all in the same folder, it's cool and simple, but I would like to use a single EXE if possible:
HttpClient.exe
libcrypto-1_1-x64.dll
libgcc_s_seh-1.dll
libssl-1_1-x64.dll
libstdc++-6.dll
libwinpthread-1.dll
Regular link command:
'Invoking: Cross G++ Linker'
g++ -L"C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib" -L"C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\lib\gcc\x86_64-w64-mingw32\lib" -L"C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\x86_64-w64-mingw32\lib" -L"C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\lib\gcc\x86_64-w64-mingw32\8.1.0" -o "HttpClient" ./src/HttpClient.o -lcrypto -lssl -lcrypt32 -lws2_32
'Finished building target: HttpClient'
11:36:01 Build Finished. 0 errors, 0 warnings. (took 342ms)
If I add the -static flag to the G++ command line, using /properties/C++ build/settings/G++ linker->Command textbox
These errors are thrown when I try to build:
g++ -static -L"C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib" -L"C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\lib\gcc\x86_64-w64-mingw32\lib" -L"C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\x86_64-w64-mingw32\lib" -L"C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\lib\gcc\x86_64-w64-mingw32\8.1.0" -o "HttpClient" ./src/HttpClient.o -lcrypto -lssl -lcrypt32 -lws2_32
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl3_record.o):ssl3_record.c:(.text+0x22f): undefined reference to `COMP_expand_block'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl3_record.o):ssl3_record.c:(.text+0x2b7): undefined reference to `COMP_compress_block'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl3_record.o):ssl3_record.c:(.text+0x1f24): undefined reference to `COMP_expand_block'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl3_record.o):ssl3_record.c:(.text+0x2c3e): undefined reference to `COMP_expand_block'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_cert.o):ssl_cert.c:(.text+0x18cd): undefined reference to `PEM_read_bio_X509'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_cert.o):ssl_cert.c:(.text+0x1aa5): undefined reference to `PEM_read_bio_X509'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_cert.o):ssl_cert.c:(.text+0x20ff): undefined reference to `X509_verify_cert_error_string'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_ciph.o):ssl_ciph.c:(.text+0x3e1): undefined reference to `COMP_get_type'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_ciph.o):ssl_ciph.c:(.text+0x420): undefined reference to `COMP_get_name'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_ciph.o):ssl_ciph.c:(.text+0x1cf1): undefined reference to `EVP_enc_null'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_ciph.o):ssl_ciph.c:(.text+0x356a): undefined reference to `COMP_get_type'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_ciph.o):ssl_ciph.c:(.text+0x3716): undefined reference to `COMP_get_name'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0xf3c): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0xf53): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x513b): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x5154): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x6496): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x64af): more undefined references to `COMP_CTX_free' follow
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x7a69): undefined reference to `X509_LOOKUP_hash_dir'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x7ab9): undefined reference to `X509_LOOKUP_file'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x8774): undefined reference to `OCSP_response_get1_basic'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x8797): undefined reference to `OCSP_resp_count'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x87a9): undefined reference to `OCSP_resp_get0'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x87c1): undefined reference to `OCSP_SINGLERESP_get1_ext_d2i'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x89c4): undefined reference to `CT_POLICY_EVAL_CTX_new'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x89ef): undefined reference to `CT_POLICY_EVAL_CTX_set1_cert'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x89fa): undefined reference to `CT_POLICY_EVAL_CTX_set1_issuer'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x8a10): undefined reference to `CT_POLICY_EVAL_CTX_set_shared_CTLOG_STORE'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x8a32): undefined reference to `CT_POLICY_EVAL_CTX_set_time'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x8a9c): undefined reference to `CT_POLICY_EVAL_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x8ad0): undefined reference to `CT_POLICY_EVAL_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x8b10): undefined reference to `CT_POLICY_EVAL_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0xa22d): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0xa246): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x772d): undefined reference to `COMP_CTX_get_method'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x774d): undefined reference to `COMP_CTX_get_method'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x7a55): undefined reference to `X509_STORE_set_default_paths'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_lib.o):ssl_lib.c:(.text+0x7b05): undefined reference to `X509_STORE_load_locations'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_rsa.o):ssl_rsa.c:(.text+0xa18): undefined reference to `PEM_read_bio_X509_AUX'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_rsa.o):ssl_rsa.c:(.text+0xac7): undefined reference to `PEM_read_bio_X509'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_rsa.o):ssl_rsa.c:(.text+0xc73): undefined reference to `PEM_read_bio_X509'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_rsa.o):ssl_rsa.c:(.text+0xddf): undefined reference to `PEM_read_bio_X509'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_rsa.o):ssl_rsa.c:(.text+0x116e): undefined reference to `PEM_read_bio_RSAPrivateKey'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_rsa.o):ssl_rsa.c:(.text+0x17ff): undefined reference to `PEM_read_bio_X509'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_rsa.o):ssl_rsa.c:(.text+0x1b9e): undefined reference to `PEM_read_bio_RSAPrivateKey'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(t1_lib.o):t1_lib.c:(.text+0x4698): undefined reference to `BN_get_rfc3526_prime_2048'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(t1_lib.o):t1_lib.c:(.text+0x4751): undefined reference to `BN_get_rfc3526_prime_3072'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(t1_lib.o):t1_lib.c:(.text+0x4761): undefined reference to `BN_get_rfc3526_prime_8192'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(t1_lib.o):t1_lib.c:(.text+0x4771): undefined reference to `BN_get_rfc3526_prime_4096'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(t1_lib.o):t1_lib.c:(.text+0x4781): undefined reference to `BN_get_rfc2409_prime_1024'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0x642): undefined reference to `SRP_Calc_B'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0x687): undefined reference to `SRP_get_default_gN'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0x70c): undefined reference to `SRP_create_verifier_BN'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0x98f): undefined reference to `SRP_Verify_A_mod_N'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0x9b4): undefined reference to `SRP_Calc_u'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0x9ed): undefined reference to `SRP_Calc_server_key'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0xaf1): undefined reference to `SRP_Verify_B_mod_N'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0xb16): undefined reference to `SRP_Calc_u'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0xb64): undefined reference to `SRP_Calc_x'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0xba2): undefined reference to `SRP_Calc_client_key'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0xe91): undefined reference to `SRP_check_known_gN_param'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(tls_srp.o):tls_srp.c:(.text+0xf44): undefined reference to `SRP_Calc_A'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(s3_enc.o):s3_enc.c:(.text+0x91): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(s3_enc.o):s3_enc.c:(.text+0xaa): undefined reference to `COMP_CTX_new'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(s3_enc.o):s3_enc.c:(.text+0x1f3): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(s3_enc.o):s3_enc.c:(.text+0x20c): undefined reference to `COMP_CTX_new'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_conf.o):ssl_conf.c:(.text+0x365): undefined reference to `X509_STORE_load_locations'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_conf.o):ssl_conf.c:(.text+0xf37): undefined reference to `X509_STORE_load_locations'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_conf.o):ssl_conf.c:(.text+0xfc7): undefined reference to `X509_STORE_load_locations'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(ssl_conf.o):ssl_conf.c:(.text+0x1055): undefined reference to `X509_STORE_load_locations'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(t1_enc.o):t1_enc.c:(.text+0x3ae): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(t1_enc.o):t1_enc.c:(.text+0x3c7): undefined reference to `COMP_CTX_new'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(t1_enc.o):t1_enc.c:(.text+0x65a): undefined reference to `COMP_CTX_free'
C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\opt\lib\libssl.a(t1_enc.o):t1_enc.c:(.text+0x673): undefined reference to `COMP_CTX_new'
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:60: HttpClient] Error 1
Any help or guidance would be greatly appreciated.
Platform used:
Eclipse CDT Version: 2021-12 (4.22.0)
Build id: 20211202-1639
OpenSSL 1.1.1
g++ (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0
Thank you,
Martin
Re: How to static link with mingw x64 C++ runtime and openssl? [message #1848825 is a reply to message #1848823] Sat, 18 December 2021 11:35 Go to previous message
The dynamic libraries are different beasts from collections of object files. They need to be along as is, or you do need static versions of the files for linking.
A fully static link is not necessary with the static libraries: the combined executable can still refer to dynamic system libraries. A fully statically linked executable is typically huge.
Previous Topic:No paths in 'Hello World' example
Next Topic:Eclipse C/C++ IDE Cannot Find Header File in the Include Folder
Current Time: Sun Jul 27 09:41:03 EDT 2025
Powered by FUDForum. Page generated in 0.28754 seconds
