Home » Eclipse Projects » Eclipse Scout » Scout Application very Slow when 10+ Users are logged in
Scout Application very Slow when 10+ Users are logged in [message #1829127] Thu, 25 June 2020 10:43 Go to next message
We have got a problem with our Application. As soon as 10+ Users are logged in simultaneously from different machines the Application gets very very slow. We dont know where the problem is.
Example:
Sorting a table different takes around 10 seconds. And the table only has around 10 Rows. This applies for every other process in the application.
Is this a known issue? Did we do something wrong? Are there any config paramters we could adjust, to solve this?
Our setup:
Backend: 1x Windows Server with Tomcat (v.9)
Frontend: 1x Linux Server with Tomcat (v.9)
Scout: v10
Thank you for helping as always :)
Re: Scout Application very Slow when 10+ Users are logged in [message #1829128 is a reply to message #1829127] Thu, 25 June 2020 10:48 Go to previous messageGo to next message
Do you see any special CPU load, memory usage, disk i/o load or network congestion on the backend, frontend or database?
Re: Scout Application very Slow when 10+ Users are logged in [message #1829131 is a reply to message #1829128] Thu, 25 June 2020 10:55 Go to previous messageGo to next message
Please also check the currentThreadCount. Does it increase when more users connect or does it stay at a low level (e.g. 10?)
Do you deploy your app regularly using Tomcat deployer without restarting the Tomcat after a new deployment?
Re: Scout Application very Slow when 10+ Users are logged in [message #1829132 is a reply to message #1829128] Thu, 25 June 2020 11:26 Go to previous messageGo to next message
I didnt notice any spikes in any of that. But i will try a collect some data and i will get back to you with that
Re: Scout Application very Slow when 10+ Users are logged in [message #1829133 is a reply to message #1829131] Thu, 25 June 2020 11:31 Go to previous messageGo to next message
So i can only check the Thread count for the backend Server. Because i dont have direct acces to the Frontend server. But on the Backend i noticed that it starts with 10 Threads that are ready. As soon as I log in with a User 1 Thread is taken by 1 User. But as soon as i get to the starting number (10) it wont create anymore Threads. So maybe that is the problem? So as soon as 10+ Users are logged in all Threads are taken and it wont create more that these 10.
Do you know if that is the problem?
I only deploy the Frontend to through the Tomcat deployer and yes as you said without restarting. On the backend I stop the Tomcat then delete the old war file and insert the new one. Then i restart it
[Updated on: Thu, 25 June 2020 11:32] by Moderator
Re: Scout Application very Slow when 10+ Users are logged in [message #1829134 is a reply to message #1829133] Thu, 25 June 2020 12:14 Go to previous messageGo to next message
Is it slow after a fresh restart of the Frontend server or does it get slow over time (after some deployments)? I don't think the backend server is the problem, there should not be a lot of concurrent threads running.
On the Frontend server, each active user creates a thread due to the long polling mechanism. So when more users log in more threads should be created. If that is not the case then this is likely your problem. Because now, a connection can only be processed as soon as one long polling connection is released (after 1 minute) because no more threads are created.
We experienced the same behavior with our demo applications (https://scout.bsiag.com/widgets, etc.). After about 1 week the apps got very slow and the currentThreadCount stopped increasing at about 10 threads. We deployed the demo apps nightly using the Tomcat deployer. About 2 weeks ago we temporarily deactivated the deployments and the apps are still running fine. For our real apps (not demo apps) we never use the tomcat deployer, that is probably why they are running fine...
Unfortunately we still don't know what the problem is, whether it is because of Tomcat 9, JDK 11 or Scout 10. It worked well with Tomcat 8, JDK 8 and Scout 9...
What JDK do you use?
Re: Scout Application very Slow when 10+ Users are logged in [message #1829136 is a reply to message #1829134] Thu, 25 June 2020 12:36 Go to previous messageGo to next message
Thank you for your answer. I will look into the Frontend server as soon as possible. I just have to wait for my coworker.
We are using OpenJDK 11
Re: Scout Application very Slow when 10+ Users are logged in [message #1829138 is a reply to message #1829134] Thu, 25 June 2020 12:49 Go to previous messageGo to next message
So I looked into the FrontEnd Tomcat Manager and there i see that the ThreadCount never goes above 10. Even when 10+ User are logged in. That might be the problem.
Do you know a Solution to this? I didnt find a Property in the Config Properties to change this behaviour.
Re: Scout Application very Slow when 10+ Users are logged in [message #1829144 is a reply to message #1829138] Thu, 25 June 2020 14:33 Go to previous messageGo to next message
Ok so the solution at least for us was indeed restarting the Tomcat of the Frontend. After that everything worked fine.
We also tested that after it worked, we deployed through the Tomcat deployer and then we had the same problem again. So it seems if you deploye through tomcat you need to restart it aswell. Dunno why but well at least it works now.
Re: Scout Application very Slow when 10+ Users are logged in [message #1832763 is a reply to message #1829127] Thu, 24 September 2020 11:28 Go to previous messageGo to next message
Hi Luis
Maybe this is because of Tomcat Bug 64765.
Within the bug a possible workaround is described. Does this work for you?
Kind regards
Mat
Re: Scout Application very Slow when 10+ Users are logged in [message #1833440 is a reply to message #1829127] Tue, 13 October 2020 05:06 Go to previous messageGo to next message
Hi Luis
A fixed version of Tomcat is available now: 9.0.39.
Does it work for you with this version (or newer)?
Mat
Re: Scout Application very Slow when 10+ Users are logged in [message #1834030 is a reply to message #1833440] Fri, 30 October 2020 09:49 Go to previous messageGo to next message
Hi Mat,
Sorry for the late reply.
I will test it as soon as i can.
I will post an update as soon as i have one here :)
Luis
Re: Scout Application very Slow when 10+ Users are logged in [message #1848630 is a reply to message #1833440] Fri, 10 December 2021 05:17 Go to previous messageGo to next message
So sorry for the late reply
We recently updated to the latest Tomcat 9.0.55. It seems to be fixed now :)
Luis
Re: Scout Application very Slow when 10+ Users are logged in [message #1848633 is a reply to message #1848630] Fri, 10 December 2021 05:23 Go to previous message
Great news. Thanks for sharing.
Previous Topic:Create WAR - found duplicate org.json objects
Next Topic:Multiple separate Scout applications in one tomcat installtion
Current Time: Mon Jul 21 08:37:50 EDT 2025
Powered by FUDForum. Page generated in 0.32701 seconds
