Home » Modeling » Papyrus » Generate output from diagram content
Generate output from diagram content [message #1848557] Tue, 07 December 2021 14:11 Go to next message
Hi All,
I hope this makes sense, newbie here...
I am trying the following: I get a set of XSD files as input, from which I generate an EMF Generator Model, then an UML model and finally a Papyrus model (based on the instructions I found here: 1). I can then create class diagrams based on the model, which gives me the UI functionality I am looking for.
I would now like to generate some XML output based only on the content of a specific class diagram. Is there a way for doing this? Every generation example I look into seems to take into account the entire model -- I only use a handful of classes from the quite large input, so I would like to limit the scope.
https:// wiki.onap.org/display/DW/Step-by-step+to+generate+Papyrus+UML+model+from+XSD+file
Re: Generate output from diagram content [message #1848575 is a reply to message #1848557] Wed, 08 December 2021 06:50 Go to previous messageGo to next message
If you have a use case, it make sense.
OK, nevertheless a diagram is a visualization of typically a part of a model. Because a diagram is a visualization, a diagram is not very well suited as a base for a transformation.
Alternative approaches are
* group the classes to be taken into account by modeling means by
- relating these classes with an element used to be the root element of the transformation (i.e. making the classes realize an artifact and using the artifact as the root element)
- classifying the classes by a stereotype or a value of a stereotype
* if possible, make the transformation selecting the right classes. In this case you take a class as root element and the transformation computes which other classes are needed.
/pica
Re: Generate output from diagram content [message #1848602 is a reply to message #1848575] Thu, 09 December 2021 08:17 Go to previous messageGo to next message
Papyrus does not have tools to convert the UML into an other xsd format. You should certainly create you own generator using the UML API.
Pauline
Re: Generate output from diagram content [message #1848603 is a reply to message #1848602] Thu, 09 December 2021 08:23 Go to previous message
or
* ATL (https://www.eclipse.org/atl/)
* Acceleo (https://www.eclipse.org/acceleo/)
* Xtext / Xtend (https://www.eclipse.org/Xtext/)
Papyrus being a member of Eclipse provides you a broad choice :-)
/Carsten
Previous Topic:simple import classes only with class names
Next Topic:Composite association has multiplicity labels on wrong (?) sides
Current Time: Mon Jul 21 11:04:47 EDT 2025
Powered by FUDForum. Page generated in 0.03830 seconds
