Generate output from diagram content [message #1848557] |
Tue, 07 December 2021 14:11  |
Hi All,
I hope this makes sense, newbie here...
I am trying the following: I get a set of XSD files as input, from which I generate an EMF Generator Model, then an UML model and finally a Papyrus model (based on the instructions I found here: 1). I can then create class diagrams based on the model, which gives me the UI functionality I am looking for.
I would now like to generate some XML output based only on the content of a specific class diagram. Is there a way for doing this? Every generation example I look into seems to take into account the entire model -- I only use a handful of classes from the quite large input, so I would like to limit the scope.
https:// wiki.onap.org/display/DW/Step-by-step+to+generate+Papyrus+UML+model+from+XSD+file
FUDForum. Page generated in 0.03510 seconds
