Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Use dynamic models to quickly develop SWT applications
Use dynamic models to quickly develop SWT applications [message #1847131] Fri, 15 October 2021 08:46 Go to next message
The dynamic model is a programming method that can realize real-time programming . XWorker is a development platform and model library for dynamic models. The dynamic model and XWorker are open source.
XWorker packages SWT into a model, and SWT-based applications can be developed through the model. The IDE for dynamic models is also developed using SWT.I hope those who are interested can take a look.
XWorker home page: https://www.xworker.org/do?sc=xworker.app.orgweb.web.Index&id=11
Examples: https://github.com/x-meta/apps
XWorker: https://github.com/x-meta/xworker
Dynamic model engine: https://github.com/x-meta/x-meta
GIF video shows real-time design examples. Unlike other interface designers, you can also modify the running SWT interface written using the model.
https://www.xworker.org/files/2021/1013/170713design_replace.gif
Re: Use dynamic models to quickly develop SWT applications [message #1848526 is a reply to message #1847131] Mon, 06 December 2021 21:17 Go to previous message
Using GUI designer tools is usually for either beginners or non-software-engineers. Expert software engineers are slowed down by GUI designers, so they resort to writing very well-designed minimalistic code instead while relying on Design Patterns and Domain Specific Languages.
Actually, if you really want to quickly develop SWT applications, just use Glimmer DSL for SWT.
I built a Metronome with it in less than 10 minutes for the initial version:
https://andymaleh.blogspot.com/2021/03/glimmer-metronome-hello-canvas.html
Tetris took me 1 day for the initial working version:
https://github.com/AndyObtiva/glimmer_tetris
Here is an article series that can walk anyone through that:
https://planetruby.github.io/gems/glimmer/05-glimmer-tetris-playfield.html
https://raw.githubusercontent.com/AndyObtiva/glimmer-dsl-swt/master/images/glimmer-tetris.png
I was later able to reuse the same Tetris code to run online on the web via Glimmer DSL for Opal:
https://github.com/AndyObtiva/glimmer-dsl-opal#tetris
https://raw.githubusercontent.com/AndyObtiva/glimmer-dsl-opal/master/images/glimmer-dsl-opal-tetris.png
I built a children's programming language based on a simplified version of Logo in about one week for the first working version:
https://github.com/AndyObtiva/dcr
https://raw.githubusercontent.com/AndyObtiva/dcr/master/images/dcr-screenshot.png
I've built a complete professional project management app with Glimmer DSL for SWT in about 11 days, taking full advantage of built-in bidirectional data-binding, which is only a single line for data-binding a table (unlike JFace Data-Binding syntax, which takes pages of code. Nonetheless, JFace Data-Binding is certainly the inspiration for data-binding features in Glimmer DSL for SWT):
https://github.com/AndyObtiva/are-we-there-yet
https://github.com/AndyObtiva/are-we-there-yet/raw/master/are-we-there-yet-screenshot-windows.png
The single data-binding code line needed to bind the table data:
items bind(Task, :list), column_properties(:project_name, :task_type, :name, :start_date, :end_date, :duration, :priority)
Extra lines are added to declaratively configure the table for editing/sorting (no manual code is needed for using TableEditor or sorting TableItems).
Full table code is here:
https://github.com/AndyObtiva/are-we-there-yet/blob/master/app/views/are_we_there_yet/task_table.rb
      table(:multi, :full_selection) { |table_proxy|
        # TODO Make resizing table columns auto-resize form fields
        @project_name_table_column = table_column {
          text 'Project'
          width CONFIG[:table_column_width_hint]
          editor :combo
        table_column {
          text 'Type'
          editor :combo
        table_column {
          text 'Task'
        table_column {
          text 'Start Date'
          editor :c_date_drop_down, property: :start_at
        table_column {
          text 'End Date'
          editor :c_date_drop_down, property: :end_at
        table_column {
          text 'Duration (hours)'
          editor :combo, :read_only
          sort_property :duration_in_hours
        table_column {
          text 'Priority'
          sort_property :priority_sort
        additional_sort_properties :project_name, :task_type, :start_date, :duration_in_hours, :name, :priority_sort, :end_date
        table_proxy.sort_by_column @project_name_table_column
        on_control_resized {
          window_width = body_root.swt_widget.shell.bounds.width
          columns = body_root.swt_widget.columns
          new_column_width = window_width.to_f / columns.size
          columns.each do |column|
            column.width = new_column_width
          end
        on_mouse_up { |event|
          table_proxy.edit_table_item(event.table_item, event.column_index)
        on_menu_detected { |event|
          column_x = event.x - event.widget.shell.bounds.x
          column_y = 0
          @column_index = nil
          # TODO offload this to a method on TableProxy
          @sort_by_menu_item.swt_widget.text = 'Sort' unless OS.windows?
          @remove_task_menu_item.swt_widget.text = 'Remove Task'
          if !event.widget.items.empty?
            @remove_task_menu_item.swt_widget.text = 'Remove Tasks' if swt_widget.selection.size > 1
            table_item = event.widget.items.first
            @column_index = event.widget.column_count.times.to_a.detect do |ci|
              table_item.getBounds(ci).contains(column_x, column_y)
            end
            @sort_by_menu_item.swt_widget.text = "Sort by #{swt_widget.columns[@column_index].text}" if @column_index && OS.windows?
          end
        menu {
          @remove_task_menu_item = menu_item {
            text "Remove Task"
            on_widget_selected {
              swt_widget.selection.map(&:data).each(&:destroy)
          unless OS.windows?
            @sort_by_menu_item = menu_item {
              text 'Sort'
              on_widget_selected { |event|
                body_root.sort_by_column(body_root.table_column_proxies[@column_index]) if @column_index
          end
Best of all, JRuby already has built-in support for Dynamic Models as you can use OpenStruct to set properties dynamically and observe them for View/Model bidirectional data-binding if you really want Dynamic Models. Most of the time, you get away just fine with Simple Models though.
Glimmer was originally an Eclipse incubation project, but later became an MIT-license free and open-source project on GitHub.
[Updated on: Mon, 06 December 2021 21:28] by Moderator
Previous Topic:Strange problem when Mac is set to Dark and Eclipse theme is Light in RCP app
Next Topic:Mac Compatibility issues with SWT and the recent patched versions of Java 8
Current Time: Mon Jul 21 06:13:13 EDT 2025
Powered by FUDForum. Page generated in 0.05277 seconds
