Home » Eclipse Projects » Mosquitto » Please help. Can't connect with websocket and TLS
Please help. Can't connect with websocket and TLS [message #1848461] Thu, 02 December 2021 17:27 Go to next message
hello everyone, you are my last help.I'm already trying Mosquitto with WebSocket and TSL for 3 days. I use version 2.0.11.
The firewall was turned off for testing.
the connection via TCP and unencrypted websocket works fine.
mosquitto.conf
allow_anonymous false
require_certificate false
password_file c:\mosquitto\user.txt
#mqtt
listener 1883 0.0.0.0
#websockets
listener 8883
protocol websockets
cafile c:\mosquitto\m2mqtt_ca.crt
certfile c:\mosquitto\m2mqtt_srv.crt
keyfile c:\mosquitto\m2mqtt_srv.key
tls_version tlsv1.2
#plugin C:\mosquitto\mosquitto_dynamic_security.dll
#plugin_opt_config_file C:\mosquitto\dynamic-security.json
websockets_log_level all
websockets_log_level 1023
log_type error
log_type warning
log_type notice
log_type subscribe
log_type unsubscribe
connection_messages true
I have attached the images of the error messages.
forbidding on uri sanitation
lws_return_http_status: return
Can anyone help me?
[Updated on: Fri, 03 December 2021 17:14] by Moderator
Re: Please help. Can't connect with websocket and TLS [message #1848479 is a reply to message #1848461] Fri, 03 December 2021 15:06 Go to previous messageGo to next message
this may have something to do with libwebsockets. Does this need to be installed/enabled?
Re: Please help. Can't connect with websocket and TLS [message #1848480 is a reply to message #1848479] Fri, 03 December 2021 17:17 Go to previous messageGo to next message
i have fixed it. I had a certificate error and extracted my .pfx to the necessary data. Now everything is working.
openssl pkcs12 -in wild.pfx -nocerts -out m2mqtt_srv.key
openssl pkcs12 -in wild.pfx -clcerts -nokeys -out m2mqtt_srv.crt
openssl pkcs12 -in wild.pfx -cacerts -nokeys -chain | openssl x509 -out m2mqtt_ca.crt
Re: Please help. Can't connect with websocket and TLS [message #1850504 is a reply to message #1848480] Sun, 06 March 2022 23:21 Go to previous message
Hi @Bastian Hildner, I'm facing similar issue in case of WebSockets with TLS, I did not understand the changes you did to fix the issue, in my case as well I have created all the certificates using OpenSSL and the same set of certificates seems to work with protocol mqtt and TLS but it fails to work in case of websockets with TLS.
reference - https://www.eclipse.org/forums/index.php/t/1109577/
[Updated on: Mon, 07 March 2022 23:29] by Moderator
Previous Topic:MQTT over WebSockets with TLS
Next Topic:Industry standard for data export
Current Time: Sun Jul 20 23:17:27 EDT 2025
Powered by FUDForum. Page generated in 0.05243 seconds
