I recently installed Eclipse (2021-09) IDE on my Ubuntu 20.04. Recently we used Netbeans for most development and remote debugging.
Using the maven project wizard I was able to generate a project with both a build.xml and pom.xml file already generated. I assume the IDE can detect the necessary plugins and configuration. My goal is to connect and debug java applications remotely to a RaspberryPi.
the pom.xml
  <modelVersion>4.0.0</modelVersion>
  <groupId>IntelligentHome</groupId>
  <artifactId>RaspberryPi</artifactId>
  <version>0.0.1-SNAPSHOT</version>
  <name>RaspberryPi</name>
  <!-- FIXME change it to the project's website -->
  <url></url>
	<build>
      <plugins>
         <plugin>
            <groupId>org.apache.maven.plugins</groupId>
            <artifactId>maven-jar-plugin</artifactId>
            <configuration>
               <archive>
                  <manifest>
                     <mainClass>IntelligentHome.RaspberryPi.App</mainClass>
                  </manifest>
               </archive>
            </configuration>
         </plugin>
      </plugins>
   </build>
  <properties>
    <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
    <maven.compiler.source>1.7</maven.compiler.source>
    <maven.compiler.target>1.7</maven.compiler.target>
  </properties>
  <dependencies>
    <dependency>
      <groupId>junit</groupId>
      <artifactId>junit</artifactId>
      <version>4.12</version>
      <scope>test</scope>
    </dependency>
  </dependencies>
<pluginRepositories>
   <pluginRepository>
    <id>maven2</id>
    <url>repo.maven.apache.org/maven2/</url>
  </pluginRepository>
</pluginRepositories>
  <build>
    <pluginManagement><!-- lock down plugins versions to avoid using Maven defaults (may be moved to parent pom) -->
      <plugins>
        <!-- clean lifecycle, see core/lifecycles.html#clean_Lifecycle -->
        <plugin>
          <artifactId>maven-clean-plugin</artifactId>
          <version>3.1.0</version>
        </plugin>
        <!-- default lifecycle, jar packaging: see core/default-bindings.html#Plugin_bindings_for_jar_packaging -->
        <plugin>
          <artifactId>maven-resources-plugin</artifactId>
          <version>3.0.2</version>
        </plugin>
        <plugin>
          <artifactId>maven-compiler-plugin</artifactId>
          <version>3.8.0</version>
        </plugin>
        <plugin>
          <artifactId>maven-surefire-plugin</artifactId>
          <version>2.22.1</version>
        </plugin>
        <plugin>
        </plugin>
        <plugin>
          <artifactId>maven-install-plugin</artifactId>
          <version>2.5.2</version>
        </plugin>
        <plugin>
          <artifactId>maven-deploy-plugin</artifactId>
          <version>2.8.2</version>
        </plugin>
        <!-- site lifecycle, see core/lifecycles.html#site_Lifecycle -->
        <plugin>
          <artifactId>maven-site-plugin</artifactId>
          <version>3.7.1</version>
        </plugin>
        <plugin>
          <artifactId>maven-project-info-reports-plugin</artifactId>
          <version>3.0.0</version>
        </plugin>
      </plugins>
    </pluginManagement>
  </build>
</project>
with the build.xml
<project name="hello" default="remote-run" basedir="."
	xmlns:artifact="antlib:org.apache.maven.artifact.ant">
    <!-- Setup RASPBERRY PI properties -->
	<property name="raspberrypi" value="192.168.4.2" />
	<property name="raspberryfolder" value="~" />
	<property name="username" value="pi" />
	<property name="password" value="raspberry" />
	<path id="maven-ant-tasks.classpath" path="${ant.libs.dir}/maven-ant-tasks-2.1.3.jar" />
	<typedef
		resource="org/apache/maven/artifact/ant/antlib.xml"
		uri="antlib:org.apache.maven.artifact.ant"
		classpathref="maven-ant-tasks.classpath" />
	<path id="maven-ant-tasks.classpath" path="lib/maven-ant-tasks-2.1.3.jar" />
	<typedef
    <!-- Add maven install target to be run before deploy -->
	<target name="maven-install">
		<artifact:mvn pom="pom.xml">
			<arg value="install"/>
		</artifact:mvn>
	</target>
    <!-- Locate the prokect jar and transfer via scp to RASPBERRY PI -->
	<target name="transfer" depends="maven-install">
		<first id="jars">
			<fileset dir="target" includes="**/*-SNAPSHOT-jar-with-dependencies.jar" />
			<fileset dir="target" includes="**/*.jar" />
		</first>
		<pathconvert pathsep="," property="jar.path" refid="jars" />
		<basename file="${jar.path}" property="jar.filename" />
		<echo>">>> Found application ${jar.path}"</echo>
		<echo>">>> Copying application to ${raspberrypi}:${raspberryfolder}/${jar.filename}"</echo>
		<scp
			localfile="${jar.path}"
			todir="${username}:${password}@${raspberrypi}:${raspberryfolder}"
			trust="true" />
	</target>
	<!-- Run java -->
	<target name="remote-run" depends="transfer">
		<echo>">>> Starting ${raspberrypi}:${raspberryfolder}/${jar.filename}"</echo>
		<sshexec
			host="${raspberrypi}"
			username="${username}"
			password="${password}"
			trust="true"
			failonerror="true"
			usepty="true"
			command="java -jar ${jar.filename}" />
	</target>
	<!-- Run java in debug mode and keep waiting for execution -->
	<target name="remote-debug" depends="transfer">
		<echo>">>> Starting ${raspberrypi}:${raspberryfolder}/${jar.filename} in debug mode"</echo>
		<sshexec
			trust="true"
			failonerror="true"
			usepty="true"
			command="java -Xdebug -Xrunjdwp:server=y,transport=dt_socket,address=8000,suspend=y -jar ${jar.filename}" />
	</target>
</project>
Running the Ant build results in this error
[artifact:mvn] [INFO] Scanning for projects...
[artifact:mvn] [INFO] ------------------------------------------------------------------------
[artifact:mvn] [INFO] Building RaspberryPi
[artifact:mvn] [INFO]    task-segment: [install]
[artifact:mvn] [ERROR] BUILD ERROR
[artifact:mvn] [INFO] Error resolving version for 'org.apache.maven.plugins:maven-resources-plugin': Plugin requires Maven version 3.0
[artifact:mvn] [INFO] For more information, run Maven with the -e switch
[artifact:mvn] [INFO] Total time: < 1 second
[artifact:mvn] [INFO] Finished at: Wed Dec 01 11:15:06 CET 2021
[artifact:mvn] [INFO] Final Memory: 12M/54M
[artifact:mvn] Java Result: 1
The current installed maven version is: mvn -version Apache Maven 3.6.3. The workbench also points to the current maven installation (Help -> Preferences -> Maven -> Installation).
What generates this error?
Removing all the plugins from the pom.xml results in no error and the .jar is executed remotely on the target.
Do I need all the plugins? What do they do?
