Home » Modeling » EMF » Generate Tests for Non-plugin Projects
Generate Tests for Non-plugin Projects [message #1848393] Tue, 30 November 2021 15:57 Go to next message
I'm using EMF in a plain Java application, not involving Eclipse plug-ins or OSGi bundles. Accordingly, I don't want my model to have the plug-in manifest and related files generated, so I set the Model Plug-in ID property blank to suppress them.
But, this results in the GenModel editor disabling the "Generate Tests" menu action. I still want to generate tests to cover my custom code. I just don't need anything to be an Eclipse/OSGi bundle.
Is there some other way to enable test generation? Or do I just need to set some Model Plug-in ID every time I want to regenerate tests and then delete it again?
Christian
Re: Generate Tests for Non-plugin Projects [message #1848410 is a reply to message #1848393] Wed, 01 December 2021 08:22 Go to previous messageGo to next message
Yes, that seems the only way.
Re: Generate Tests for Non-plugin Projects [message #1848412 is a reply to message #1848410] Wed, 01 December 2021 08:41 Go to previous messageGo to next message
Thanks, Ed!
Glad to know I haven't missed something.
Christian
Re: Generate Tests for Non-plugin Projects [message #1848428 is a reply to message #1848412] Wed, 01 December 2021 14:39 Go to previous message
Hi Christian
If you use an MWE2 script to invoke GenModel, (and everything else of interest), your script can automatically do the tweaks for you. Nowadays MWE2 seems to have a GenModel bean, otherwise you can use the /org.eclipse.ocl.examples.build/src/org/eclipse/ocl/examples/build/utilities/GenerateModel.java bean that I developed to workaround a now-fixed EMF bug wrt standalone usage.
Ed Willink
Previous Topic:Automatically set the value of a property
Next Topic:[CDO] Increasing prefetch performance
Current Time: Mon Jul 21 00:41:30 EDT 2025
Powered by FUDForum. Page generated in 0.26574 seconds
