Home » Modeling » EMF » UML/XMI resource loader connects to www.eclipse.org(During maven build, build gets stuck for minutes behind firewall)
UML/XMI resource loader connects to www.eclipse.org [message #1847988] Tue, 16 November 2021 05:55 Go to next message
During maven build with EMF on a host behind firewall, build gets stuck for minutes.
Observation is that this is due to attempt to connect directly to internet.
Can this connection attempt be disabled?
Note that after connection timeout, the build continues without problems.
java    9772 user   31u  IPv4              74651       0t0      TCP ip-10-112-143-149.internal:57862->www.eclipse.org:http (SYN_SENT)
[INFO] "main" #1 prio=5 os_prio=0 tid=0x00007f9094050800 nid=0x24ee runnable [0x00007f909a9cd000]
[INFO]    java.lang.Thread.State: RUNNABLE
[INFO] 	at java.net.PlainSocketImpl.socketConnect(Native Method)
[INFO] 	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
[INFO] 	- locked <0x00000000e2bbcea0> (a java.net.SocksSocketImpl)
[INFO] 	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
[INFO] 	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
[INFO] 	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
[INFO] 	at java.net.Socket.connect(Socket.java:607)
[INFO] 	at java.net.Socket.connect(Socket.java:556)
[INFO] 	at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
[INFO] 	at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
[INFO] 	at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
[INFO] 	- locked <0x00000000e2bbce18> (a sun.net.www.http.HttpClient)
[INFO] 	at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
[INFO] 	at sun.net.www.http.HttpClient.New(HttpClient.java:339)
[INFO] 	at sun.net.www.http.HttpClient.New(HttpClient.java:357)
[INFO] 	at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1226)
[INFO] 	at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1162)
[INFO] 	at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1056)
[INFO] 	at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:990)
[INFO] 	at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1570)
[INFO] 	- locked <0x00000000e2bbc308> (a sun.net.www.protocol.http.HttpURLConnection)
[INFO] 	at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1498)
[INFO] 	at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:207)
[INFO] 	at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2589)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2476)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1353)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1522)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1044)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:82)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1026)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:720)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:190)
[INFO] 	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509)
[INFO] 	at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumentParser.java:182)
[INFO] 	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1339)
[INFO] 	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2784)
[INFO] 	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
[INFO] 	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
[INFO] 	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:842)
[INFO] 	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:771)
[INFO] 	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
[INFO] 	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
[INFO] 	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
[INFO] 	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
[INFO] 	at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
[INFO] 	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1563)
[INFO] 	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1342)
[INFO] 	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
[INFO] 	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
[INFO] 	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
[INFO] 	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:220)
[INFO] 	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:209)
[INFO] 	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:269)
[INFO] 	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1477)
[INFO] 	at org.eclipse.uml2.uml.internal.impl.StructuralFeatureImpl.getType(StructuralFeatureImpl.java:221)
[INFO] 	at org.eclipse.uml2.uml.internal.operations.ElementOperations.getExtension(ElementOperations.java:1189)
[INFO] 	at org.eclipse.uml2.uml.internal.operations.ElementOperations.applyStereotype(ElementOperations.java:1498)
[INFO] 	at org.eclipse.uml2.uml.internal.impl.ElementImpl.applyStereotype(ElementImpl.java:504)
Re: UML/XMI resource loader connects to www.eclipse.org [message #1847993 is a reply to message #1847988] Tue, 16 November 2021 10:35 Go to previous messageGo to next message
This option can be used to turn that off:
org.eclipse.emf.ecore.xmi.XMLResource.OPTION_USE_PACKAGE_NS_URI_AS_LOCATION
You could put in into org.eclipse.emf.ecore.resource.ResourceSet.getLoadOptions() so that all resource loads avoid that.
Re: UML/XMI resource loader connects to www.eclipse.org [message #1847994 is a reply to message #1847993] Tue, 16 November 2021 11:53 Go to previous messageGo to next message
Eclipse OCL used to have a bad problem whereby an attempt to access the nonexistent http://www.eclipse.org/ocl/1.1.0/oclstdlib.ecore was made at the start of every OCL compilation. The failure fell back to built-in functionality, but burned a modest amount of time for all users, and gave a painful delay for no Internet.
Switching off the access is good, but the need for the access at all is a bug.
I therefore developed org.eclipse.ocl.examples.xtext.tests.NoHttpURIHandlerImpl to give a JUnit test fail if any attempt is made to access the Internet. This forces me to fix rather than hide bugs. For the particular case of the synthetic http://www.eclipse.org/ocl/1.1.0/oclstdlib.ecore, it required the functionality to be less synthetic and to provide a regular EMF registration so that the access hits a Java model, not the Internet.
Ed Willink
Re: UML/XMI resource loader connects to www.eclipse.org [message #1848027 is a reply to message #1847993] Wed, 17 November 2021 10:10 Go to previous message
Ed Merks wrote on Tue, 16 November 2021 15:35
Setting this option to true seems to solve the problem.
Thank you!
Mudi Obada
Previous Topic:Reference elements from other Ecore models
Next Topic:Large containment reference performance
Current Time: Wed Sep 17 02:56:44 EDT 2025
Powered by FUDForum. Page generated in 0.04083 seconds
