| Re: Eclipse installer can't find my jdk or jre [message #1847904 is a reply to message #1847900] |
Fri, 12 November 2021 00:43  |
I don't know which installer you are using, but the latest ones contain a JRE so would not have the problem you show. The older installers look in the registry (but the Java vendors keep changing the keys under which they store the information such that an other installer can't find a newer JRE at a newer key location). The installers also look on your PATH and JAVA_HOME environment variables and is not finding a JRE there either. Perhaps it's finding stale entries in your registry or in those environment variables.
You can use this "latest" installer to install any older version of Eclipse if that's what you need to do:
http://www.eclipse.org/downloads/download.php?file=/oomph/products/eclipse-inst-jre-win64.exe
But the problem you are trying to fix is easily addressed via Nitin's suggestion.
FUDForum. Page generated in 0.03651 seconds
