Home » Eclipse Projects » Sirius » How to call own Java Method in Sirius
How to call own Java Method in Sirius [message #1847407] Tue, 26 October 2021 07:21 Go to next message
Hi, I want to call my own java method when the user clicked to the diagram element. How can I do it? I can not use Services class in VSP. What should I do? Should I use the External Java Actions? Is there any tutorial for external java actions?
Re: How to call own Java Method in Sirius [message #1847498 is a reply to message #1847407] Fri, 29 October 2021 03:47 Go to previous messageGo to next message
You mention "when the user clicked to the diagram element". Do you mean a single click? There is no action triggered by Sirius in this case, a single click simply sets the selection.
If you mean double-click, you can define a "Double Click Tool" on the corresponding mapping, and perform whatever action you want in the body of the too.
External Java Actions are documented here: https://www.eclipse.org/sirius/doc/specifier/general/Model_Operations.html#external_java_action
Why can't you use Java services? They have pretty minimal requirements (especially compared to External Java Actions) and can be used anywhere an interpreted expression is used.
Re: How to call own Java Method in Sirius [message #1847609 is a reply to message #1847498] Tue, 02 November 2021 06:17 Go to previous messageGo to next message
Pierre-Charles David wrote on Fri, 29 October 2021 07:47
I mean double click, I can't use the Java Services. Because I have a problem to call my services. I don't know why but I can't access to my service methods from odesign file.
Re: How to call own Java Method in Sirius [message #1847804 is a reply to message #1847609] Mon, 08 November 2021 18:20 Go to previous messageGo to next message
Indeed, you should use a double click tool in the end, but before that fix the problem with your java services. You don't have to use java services, but it quickly become an easy solution with more complex tools. When you created your Viewpoint Specification Project (project with the .odesign), it should have created a class with the name of your viewpoint and ending by services (if you called your odesign project "AwesomeProject" the java service class will be named "AwesomeProjectServices"). Each public java method you add to this class is accessible from your odesign, in the "interpreted expression" fields like "semantic candidate expression" (all the text fileds with a yellow background). If you have a java service named "myJavaService", in the odesign you can call it with the expression aql:self.myJavaService. Remember that the class of the first parameter of the java service should match the class of the context where the expression will be executed. For instance, if you make a double click tool for a node mapping with the domain class "MyClass", then the java service should have as first argument a "MyClass" element. You can have your service with a first element as an EObject as a first test, but you will probably want to switch it to a proper type later in order to only have the service for the good context when you are working in your odesign.
Steve
Re: How to call own Java Method in Sirius [message #1848011 is a reply to message #1847804] Wed, 17 November 2021 07:07 Go to previous message
Steve Monnier wrote on Mon, 08 November 2021 23:20
Steve
Thank you
Previous Topic:Model changed during edition warning for numeric attributes
Next Topic:Format exception handling in property views
Current Time: Mon Jul 21 02:25:12 EDT 2025
Powered by FUDForum. Page generated in 0.30048 seconds
