Home » Modeling » QVT-OML » Can we map two abstract classes?
Can we map two abstract classes? [message #1847566] Mon, 01 November 2021 09:56 Go to next message
Hi all,
I have the following two metamodels:
This is the source metamodel: index.php/fa/41222/0/
And this is the target metamodel: index.php/fa/41223/0/
Up til now, I have written the following transformation in QVTo.
modeltype A uses metamodelA('http://www.example.org/metamodelA');
modeltype B uses metamodelB('http://www.example.org/metamodelB');
transformation test(in srcModel:A, out trgModel:B);
main() {
srcModel.rootObjects()[A::Map] -> map Map2Map();
abstract mapping Map:: abstractmapping() : B::Maps {
   name := self.name;
abstract mapping Element:: Element2Element() : B::Element {
   name := self.name;
mapping Map :: Map2Map() : B::Map
inherits Map:: abstractmapping
element := self.element -> map Element2Element();
However, I am having issues with element := self.element... line.
It says :
The type 'test::Bag(Element)' does not conform to the type 'metamodelB::Element' of the property 'element'
Maybe even the Element2Element() abstract mapping is not correct, but I am not quite sure how to proceed with this line.
Any help is appreciated.
Thank you!
Re: Can we map two abstract classes? [message #1847570 is a reply to message #1847566] Mon, 01 November 2021 10:49 Go to previous messageGo to next message
Hi. John
No. It makes no sense. Consider Java, you cannot create a new instance of java.util.List; you must create an instance of concrete derived class such as ArrayList.
Just the same with models, you cannot create an incomplete instance, since it violates well-formedness principles. Not sure which WFR it might be; just common sense.
I suspect you want to use disjuncts so that you can specify alternative concrete derivations that may indeed inherit an abstract implementation.
You can find some examples of abstract/inherits/disjuncts in
https://git.eclipse.org/r/plugins/gitiles/ocl/org.eclipse.ocl/+/refs/heads/master/examples/org.eclipse.ocl.examples.build/src/org/eclipse/ocl/examples/build/qvto/UML2EcoreSynthesizer.qvto
Ed Willink
Re: Can we map two abstract classes? [message #1847572 is a reply to message #1847570] Mon, 01 November 2021 11:10 Go to previous messageGo to next message
Hi Ed,
Do you have any specific idea in this case on how to implement that?
Because I have tried using abstract/inherit/disjunct in other cases and this one too . For Maps it works, but for Element no. Source metamodel as before:
index.php/fa/41224/0/
And the target metamodel:
index.php/fa/41225/0/
In this case I do use what you mentioned in the following code snippet:
main() {
srcModel.rootObjects()[A::Map] -> map toMap();
   name := self.name;
mapping Map:: toMap() : B::Maps
disjuncts Map :: Map2Map2, Map :: Map2Map {}
   name := self.name;
element := self.element -> map Elements();
mapping Map :: Map2Map2() : B::Map2
mapping A::A :: A2A() : B::A
inherits Element:: Element2Element
mapping A::B :: B2B() : B::B
mapping Element:: Elements() : B::Element
disjuncts A::A :: A2A, A::B :: B2B{}
However, in line : element := self.element -> map Elements();
I still get:
Many thanks in advance!
[Updated on: Mon, 01 November 2021 11:21] by Moderator
Re: Can we map two abstract classes? [message #1847573 is a reply to message #1847572] Mon, 01 November 2021 12:01 Go to previous messageGo to next message
Hi John
The thing is that you are using the -> notation to invoke your mapping. This implies two things:
1. It implicitly converts the source element into a Set(Element)
2. It invokes the mapping on each element of that Set, resulting in a Bag(Element)
Of course that Bag cannot be assigned to the target element. Use -> only if you are invoking an operation on a collection. Does it work if you just replace the -> notation with the usual . notation?
element := self.element.map Element2Element();
Kind regards
Christopher
Re: Can we map two abstract classes? [message #1847574 is a reply to message #1847573] Mon, 01 November 2021 12:07 Go to previous messageGo to next message
Hi Christopher,
Thank you for your reply, but now I get the following error:
Can not call abstract mapping 'metamodelA::Element::Element2Element' with abstract out/result parameter type directly. Use with inherits, disjuncts, merges in other mappings
Re: Can we map two abstract classes? [message #1847576 is a reply to message #1847574] Mon, 01 November 2021 12:26 Go to previous messageGo to next message
It works if I write
element := self.element.map Elements();
Many thanks :)
Just a question out of curiosity. Is this the simplest way how to make this transformation in QVTo?
Re: Can we map two abstract classes? [message #1847583 is a reply to message #1847576] Mon, 01 November 2021 15:46 Go to previous message
John Henbergs wrote on Mon, 01 November 2021 12:26
It depends on how you define 'simple'. There is no need to use inherits, you can also duplicate the respective code into each mapping. Thereby, you might improve the understandabaility of your transformation but you certainly affect its maintainability.
I see no way to get rid of the disjuncts in your case, but there is something I don't understand. You didn't specify any conditions in your disjunctive mappings, so the disjunction will always execute Map :: Map2Map2 (because it's first), never Map :: Map2Map. Hence you don't need the disjuncts at all.
Kind regards
Christopher
[Updated on: Mon, 01 November 2021 15:46] by Moderator
Previous Topic:Only recognise the first model type
Next Topic:Create new element in target model
Current Time: Mon Jul 21 00:27:54 EDT 2025
Powered by FUDForum. Page generated in 0.05336 seconds
