Home » Language IDEs » C / C++ IDE (CDT) » Debug problem.
Debug problem. [message #184710] Thu, 15 February 2007 07:20 Go to next message
I'm very new with CDT and examined following problem:
1. I created managed C++ project
2. Then creates main.cpp file with printing "Hello, world!" functionality
3. Then run it with success
4.When I tried to debug project the execution stoped in main, but source
was not linked. I tried to edit lookup path but without any success.
the stack: 1 main() at
\cygdrive\m\Settings\Eclipse\3.2.1\workspace\Managed C++ Test\main.cpp:7
0x00401176
Please tell me how to link sources? My platform is Windows XP and last
cygwin.
Re: Debug problem. [message #184719 is a reply to message #184710] Thu, 15 February 2007 07:45 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
I think your problem is having a directory with spaces in the name: "Managed C++
Test" (AFAIK this is a limitation with Cygwin). Try again, with a non-spacey
directory name.
Derek
> 0x00401176
> cygwin.
Re: Debug problem. [message #184750 is a reply to message #184710] Thu, 15 February 2007 08:06 Go to previous messageGo to next message
Sergey,
in short words, you must create a pathentry mapping from /cygdrive/m to m:\
In the eclipse IDE, go to menu Window -> Preferences -> C/C++ -> Debug ->
Common Source Lookup Path -> Add.
From the list of lookup containers, choose Path Mapping and OK. You get a
New Mapping in the list.
Select the mapping and then Edit. In the Modify the path mappings dialog
select Add and then enter
/cygdrive/m as the compilation path and
m:\ as the local file system path.
This setting will apply to any debug sessions launched from this workspace.
You can also modify the settings in each individual launch configuration.
HTH
Norbert
Re: Debug problem. [message #184934 is a reply to message #184750] Fri, 16 February 2007 08:03 Go to previous message
Thank you very much!
That works!
"Norbert Ploett" <norbert.ploett@siemens.com> wrote in message
news:1171544774.165549@baruth.khe.siemens.de...
> Sergey,
> m:\
> workspace. You can also modify the settings in each individual launch
> configuration.
> HTH
> Norbert
Previous Topic:how to get Active Build Configuration?
Next Topic:Navigation...
Current Time: Fri Jul 25 21:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.04287 seconds
