Home » Newcomers » Newcomers » Help for running Eclipse on a legacy Mac OS (10.9)
Help for running Eclipse on a legacy Mac OS (10.9) [message #1847381] Mon, 25 October 2021 14:07 Go to next message
I have an old iMac running Mac OS 10.9. I was curious to see if I could get Eclipse to run on it. I've been trying various versions of Eclipse. The last version I was able to run was 3.6. I read that 4.4 should be able to run, but I get an error which is beyond my level of competence,
If this system is too old for anybody to bother, I understand.
[Updated on: Mon, 25 October 2021 14:09] by Moderator
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847384 is a reply to message #1847381] Mon, 25 October 2021 14:46 Go to previous messageGo to next message
The Java on your computer may be 32 bits.
The current Eclipse versions need 64 bit Java to run.
The hardware running OS X 10.9 should be OK for 64 bits.
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847399 is a reply to message #1847384] Mon, 25 October 2021 21:58 Go to previous messageGo to next message
Because Apple doesn't support an OS higher than Lion (10.7) on my iMac, I installed a modified version of 10.9 (Mavericks) on my machine.
64 bit apps appear to run just fine. I don't understand why Eclipse 4.4 won't run, because it was certified at the time to run on 10.9.
When I get home I will attach the metadata.log file.
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847429 is a reply to message #1847384] Tue, 26 October 2021 18:00 Go to previous messageGo to next message
Current versions of Eclipse require 10.10. Do you know the youngest version of Eclipse to run on 10.9?
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847440 is a reply to message #1847429] Wed, 27 October 2021 04:20 Go to previous messageGo to next message
Get Java JDK from Java pages. Remember to select 64 bit version, if there are choices. Version 8 (also called 1.8) should fit in well, and the information is a bit fuzzy, version 11 could.
The Java version limits what release of Eclipse you can run.
Please use the Eclipse installer to set Eclipse up.
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847455 is a reply to message #1847440] Wed, 27 October 2021 21:08 Go to previous messageGo to next message
The current version of the Eclipse installer requires 10.10 and earlier versions crash.
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847468 is a reply to message #1847455] Thu, 28 October 2021 05:53 Go to previous messageGo to next message
Have you attempted to install Java 11?
It might work. Sorry, I do not have an OS X older than El Capitan, anymore.
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847491 is a reply to message #1847468] Thu, 28 October 2021 20:38 Go to previous messageGo to next message
Yes, I installed Java 11.
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1854188 is a reply to message #1847491] Fri, 05 August 2022 04:00 Go to previous message
Thanks for the suggestions! I have just got an old Mac and would like to set it up.
Previous Topic:UnsupportedConfigurationException: Project workspace location matches workspace root
Next Topic:***Install eclipse plugin via command line***
Current Time: Sat Nov 01 01:39:53 EDT 2025
Powered by FUDForum. Page generated in 0.67297 seconds
