Home » Newcomers » Newcomers » Invalid thread access
Invalid thread access [message #1847260] Thu, 21 October 2021 08:35 Go to next message
When I try to open keyboard shortcuts with Window . preferences - General - Keys it shows error: "Invalid thread access" .
Eclipse IDE for Enterprise Java and Web Developers (includes Incubating components)
Version: 2021-03 (4.19.0)
Build id: 20210312-0638
OS: Windows 10, v.10.0, x86_64 / win32
Java version: 11.0.5
Is there a possible fix for this issue?
Thank you!
Re: Invalid thread access [message #1847270 is a reply to message #1847260] Thu, 21 October 2021 10:39 Go to previous messageGo to next message
Have you tried the current 2021-09 release?
Re: Invalid thread access [message #1847308 is a reply to message #1847270] Fri, 22 October 2021 06:02 Go to previous messageGo to next message
no, I have not, this release is what we use standard.
Actually I think it was working after setting up Eclipse, but the problem appeard after I installed a language pack.
If it helps I found this stack trace in the problems tab:
java.lang.IllegalStateException: Conflicting handlers: {[org.eclipse.ui.internal.handlers.NewEditorHandler,  for 'org.eclipse.ui.window.newEditor',  in WorkbenchContext, active=true, sourcePriority=0, participating=true]} vs {[org.eclipse.ui.internal.handlers.NewEditorHandler,  for 'org.eclipse.ui.window.newEditor',  in WorkbenchContext, active=true, sourcePriority=0, participating=true]} in: org.eclipse.ui.contexts.dialog
	at org.eclipse.ui.internal.handlers.LegacyHandlerService$HandlerSelectionFunction.compute(LegacyHandlerService.java:145)
	at org.eclipse.e4.core.internal.contexts.ValueComputation.get(ValueComputation.java:70)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:271)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:282)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.get(EclipseContext.java:237)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.lookUpHandler(HandlerServiceImpl.java:103)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.handlerChanged(E4HandlerProxy.java:114)
	at org.eclipse.core.commands.AbstractHandler.fireHandlerChanged(AbstractHandler.java:77)
	at org.eclipse.ui.internal.handlers.HandlerProxy.lambda$0(HandlerProxy.java:248)
	at org.eclipse.ui.internal.services.EvaluationReference.evaluate(EvaluationReference.java:119)
	at org.eclipse.ui.internal.services.EvaluationReference.changed(EvaluationReference.java:103)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:108)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:364)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:379)
	at org.eclipse.ui.internal.services.EvaluationService$1.changed(EvaluationService.java:79)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.activate(EclipseContext.java:683)
	at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener$2.run(ShellActivationListener.java:130)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
	at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener.activate(ShellActivationListener.java:126)
	at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener.handleEvent(ShellActivationListener.java:76)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1270)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1042)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1067)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
	at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1521)
	at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2291)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4757)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1480)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2263)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4930)
	at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
	at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:211)
	at org.eclipse.swt.widgets.Shell.open(Shell.java:1269)
	at org.eclipse.jface.window.Window.open(Window.java:795)
	at org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPreferencesAction.java:66)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:474)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:580)
	at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:414)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4209)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1043)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4026)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3626)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1157)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:566)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1434)
Re: Invalid thread access [message #1853688 is a reply to message #1847308] Wed, 13 July 2022 12:01 Go to previous messageGo to next message
I have now used this version 2021-09 and the outline window is there after installing the language pack. Good stuff.
Re: Invalid thread access [message #1855420 is a reply to message #1847260] Thu, 13 October 2022 07:27 Go to previous messageGo to next message
the outline windows is again not shown with the below exception after installing language pack in build :
Version: 2022-06 (4.24.0)
Build id: 20220609-1112
[Updated on: Thu, 13 October 2022 07:29] by Moderator
Re: Invalid thread access [message #1855424 is a reply to message #1855420] Thu, 13 October 2022 08:39 Go to previous message
I don't think an IDE should have rwt installed; it conflicts with swt. I don't even expect the RAP tools to be installed in the JEE package. It looks like something else that doesn't work well was installed in your IDE.
Previous Topic:Failed to unzip JDK 17 classes.jsa on Linux
Next Topic:Can't install Eclipse
Current Time: Thu Jun 12 20:48:39 EDT 2025
Powered by FUDForum. Page generated in 0.21023 seconds
