Home » Modeling » Papyrus » Papyrus doesnt work on MACOS BigSur(Papyrus doesnt work on MACOS BigSur)
Papyrus doesnt work on MACOS BigSur [message #1845051] Mon, 04 October 2021 12:30 Go to next message
We generally use java 8 for development. Previously 2020-06 version of Papyrus used to work but after receiving a laptop with Bigsur when I installed same version with java 8 Papyrus never came up it always says "Failed to create java virtual machine"
below is the /usr/libexec/java_home -V
Matching Java Virtual Machines (2):
1.8.291.10 (x86_64) "Oracle Corporation" - "Java" /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home
1.8.0_291 (x86_64) "Oracle Corporation" - "Java SE 8" /Library/Java/JavaVirtualMachines/jdk1.8.0_291.jdk/Contents/Home
I even tried giving the path in vm in info.plist "/Library/Java/JavaVirtualMachines/jdk1.8.0_291.jdk/Contents/Home"
Re: Papyrus doesnt work on MACOS BigSur [message #1845110 is a reply to message #1845051] Thu, 07 October 2021 07:47 Go to previous messageGo to next message
2020-06 runs with JDK 1.8.
From 2020-12 papyrus 5.0 runs with jdk11.
What is exaclty the version of papyrus you want to use?
Papyrus Team,
Re: Papyrus doesnt work on MACOS BigSur [message #1845112 is a reply to message #1845110] Thu, 07 October 2021 10:07 Go to previous messageGo to next message
I tried both the versions that you mentioned Papyrus is not working on BigSur. It always throws error. I tried all the fixes available on internet none of them worked. Finally I installed plugin in eclipse and I am using the eclipse plugin.
Just FYI: New Papyrus installation on BigSur doesnt work
[Updated on: Thu, 07 October 2021 10:08] by Moderator
Re: Papyrus doesnt work on MACOS BigSur [message #1847097 is a reply to message #1845112] Thu, 14 October 2021 09:17 Go to previous messageGo to next message
I would like to understand. What have you tried to download? RCP?
Re: Papyrus doesnt work on MACOS BigSur [message #1848941 is a reply to message #1845051] Sat, 25 December 2021 11:35 Go to previous messageGo to next message
I installed with success in Monterey Apple silicon.
1. install papyrus-2020-12-5.0.0-macosx64
2. install jdk-11.0.13.jdk
3. added to Info.plist
<string>-vm</string><string>/Library/Java/JavaVirtualMachines/jdk-11.0.13.jdk/Contents/Home/bin/java</string>
Re: Papyrus doesnt work on MACOS BigSur [message #1849182 is a reply to message #1848941] Thu, 06 January 2022 07:49 Go to previous messageGo to next message
Try it : https://www.eclipse.org/downloads/download.php?file=/oomph/epp/2021-12/R/eclipse-inst-jre-mac64.dmg
Then update it by adding papyrus update site https://download.eclipse.org/modeling/mdt/papyrus/updates/releases/2021-12 by using menu Help>Intall new software
Re: Papyrus doesnt work on MACOS BigSur [message #1849186 is a reply to message #1849182] Thu, 06 January 2022 10:10 Go to previous message
Just for your information, we include the JRE in the RCP for Papyrus 6.0 on eclipse 2021-12 [1]. May be you can try it.
HTH,
Pauline
1] https://www.eclipse.org/papyrus/download.html
Previous Topic:Cannot install Papyrus SW Designer 2.0 in Eclipse 2021-12 / Papyrus 6.0
Next Topic:Helping me to update the "How to add a new generator" wiki entry?
Current Time: Sun Jul 20 21:54:03 EDT 2025
Powered by FUDForum. Page generated in 0.06278 seconds
