Home » Language IDEs » ServerTools (WTP) » the xdoclet integration needs serious re-factoring or at least enhancement
the xdoclet integration needs serious re-factoring or at least enhancement [message #184598] Wed, 13 December 2006 12:00 Go to next message
There are several flaws with the current xdoclet integration
1. there is no way to define the memory settings for ant. The xdoclet
generation is invoked from within eclipse in separate jvm, so giving eclipse
more memory does not help. For the amount of beans we have in our product we
are always running out of memory when running xdoclet with the the standard
memory. ANT_OPTS seems to be completely ignored.
2. I always thought the way the JBoss plugin works is very good. The
possibility to configure any xdoclet aspect is very nice and the fact that
you end up with an xdoclet ant script per project is a clean approach. And
it also enables me get around the memory issue. I just need to configure my
own ant task with a separate jvm and a -Xmx setting.
WTP is also generating an xdoclet build file but not per project. It is in
<workspacedir> \.metadata\.plugins\org.eclipse.jst.j2ee.ejb.annotations.xdo clet\tempAnt.xml
and includes a property file that contains project specific paths. That
indicates that these files are re-generated every time I run xdoclet -
unless you can have only one ejbmodule per workspace which I doubt. What was
the reasoning behind that?
3. the generated xdoclet build script contains xdoclet.force=true which
means everything gets regenerated ignoring timestamps. That might be ok for
small projects, but we have dozens of EJBs. I am not complaining about build
times, because we are not constantly changing DD relevant things, but it is
a complete nightmare from a CVS point-of-view. If I change one interface and
run xdoclet, CVS is flagging several hundred files as changed instead of
just 3-5. Changing the property to false is obviously an option, but the
fact that the build file seems to be a temporary one makes it very nasty. I
would expect this as an option in the xdoclet configuration.
I guess my main criticism is why everyone is trying to invent the wheel
again and again instead of at least looking into existing solutions (in this
case it is the WTP team, but there are lots of other examples not only
within eclipse for it).
The server and publish part of WTP is nice. I like that. But the xdoclet
part is far worse than the solution provided by the jboss plugin.
Of course just my opinion... But it definitely is a nightmare for us and is
preventing us to go with WTP.
Re: the xdoclet integration needs serious re-factoring or at least enhancement [message #184614 is a reply to message #184598] Wed, 13 December 2006 12:16 Go to previous messageGo to next message
Originally posted by: sharper3.austin.dot.rr.dot.com
Ulf,
Have you looked in to JBoss's "JBossIDE-Core" package? The way I read it, you
can download that package separately and add it to a WTP installation. The
Core package says it contains the JBoss XDoclet, Packaging, and J2EE Wizards.
I agree about the JBoss XDoclet package, it is very nice. And I have used the
Packaging as well.
You can find the download here:
http://labs.jboss.com/portal/jbosside/download/index.html
I dug around through some of the forums and found a little further discussion,
but not a whole lot.
I'd be interested to hear if other people have done this successfully.
scott
In article <elpbd6$1j8$1@utils.eclipse.org>, "Ulf Gohde"
>tempAnt.xml
Re: the xdoclet integration needs serious re-factoring or at least enhancement [message #184658 is a reply to message #184614] Thu, 14 December 2006 04:34 Go to previous messageGo to next message
I am running the JBoss plugin (the newest beta2) together with WTP.
The issues I found so far:
1. The jboss 3.2 server adapter that comes with the JBoss plugin seems to
have re-publish problems with WTP ear projects. I haven't tried 4.0, but
most of our customers are still on 3.2.7.
2. The jboss 3.2.3 server adpater that comes with WTP doesn't seem to work
properly with jboss 3.2.7
Until now we basically used the JBoss plugin and have our own ant scripts to
do all the packaging and deployment. Seems we have to stick with that for a
while....
"Scott Harper" <sharper3@austin.dot.rr.dot.com> wrote in message
news:elpch5$gmt$2@utils.eclipse.org...
> Ulf,
> you
> The
> Wizards.
> the
> Packaging as well.
> discussion,
> scott
>>eclipse
>>we
>>standard
>>my
>>tempAnt.xml
>>was
>>for
>>build
>>is
>>and
>>I
>>this
>>is
Re: the xdoclet integration needs serious re-factoring or at least enhancement [message #184665 is a reply to message #184658] Thu, 14 December 2006 05:20 Go to previous messageGo to next message
Scott,
so, to answer your question using the jboss plugin in combination WTP seems
to be ok apart from the plugin being beta and therefore probably not
completely bug free.
But instead of mixing two J2EE development plugins it would be nice to use
one instead. Especially because our product runs against several AppServer
(JBoss, Weblogic, Websphere) and what I have seen so far in WTP is nice. The
only thing that is a mess is the xdoclet part.
"Ulf Gohde" <ulf.gohde@banctec.co.uk> wrote in message
news:elr5lb$7pv$1@utils.eclipse.org...
> to do all the packaging and deployment. Seems we have to stick with that
> for a while....
>> Ulf,
>> it, you
>> The
>> Wizards.
>> used the
>> Packaging as well.
>> discussion,
>> scott
>>>eclipse
>>>we
>>>standard
>>>that
>>>And
>>>my
>>>in
>>>tempAnt.xml
>>>was
>>>for
>>>build
>>>is
>>>and
>>>I
>>>this
>>>is
Re: the xdoclet integration needs serious re-factoring or at least enhancement [message #184783 is a reply to message #184665] Thu, 14 December 2006 11:05 Go to previous messageGo to next message
Well, *for the time being* we are focused on Tomcat. I think WTP does
everything we need, except for the xdoclet part.
As an aside, my install of the all-in-one WTP package (1.5.2) gives me an
error that the xdoclet-1.2.1.jar library can't be found. Do you know anything
about that? So basically, as is, I can't do *any* xdoclet from WTP until I
get worked around that. It was suggested in a different thread that I just
download that jar from sourceforge and put it out in my environment somewhere,
but that just doesn't seem like the clean way to do it.
So I have been considering the JBoss plugin, mainly for the xdoclet stuff. I
agree that the packaging and all can be handled pretty nicely from ant.
Can you install just the xdoclet part of the JBoss plugin? Or do you get it
all?
Of course, the "for the time being" caveat above is admittedly short-sighted.
So I agree with you that a single integrated tool would be best.
In article <elr8b4$tar$1@utils.eclipse.org>, "Ulf Gohde"
>Scott,
>> for a while....
>>> Ulf,
>>> it, you
>>> The
>>> Wizards.
>>> used the
>>> Packaging as well.
>>> discussion,
>>> scott
>>>>eclipse
>>>>we
>>>>standard
>>>>that
>>>>And
>>>>my
>>>>in
>et\
>>>>tempAnt.xml
>>>>was
>>>>for
>>>>build
>>>>is
>>>>and
>>>>I
>>>>this
>>>>is
Re: the xdoclet integration needs serious re-factoring or at least enhancement [message #184933 is a reply to message #184783] Fri, 15 December 2006 06:40 Go to previous messageGo to next message
I don't think you can just download the xdoclet part. But that shouldn't be
a problem. Just don't use all the other stuff.
I used the eclipse update mechanism to download (download site:
http://download.jboss.org/jbosside/updates/development)
JBoss Eclipse IDE 2.0.0.Beta2
JBossIDE JBossAS Adapter Feature 1.0.0.Beta2
org.jboss.ide.eclipse.ejb3.feature 1.0.0.Beta2 (I don't think that that is
necessary though)
one of these (I think the last one) requirese JBoss AOP
JBoss AOP Tools 1.2.0.Beta2
news:elrsp2$e26$1@utils.eclipse.org...
> anything
> I
> just
> somewhere,
> I
> it
> all?
> short-sighted.
>>Scott,
>>seems
>>The
>>> to
>>> work
>>> scripts
>>> for a while....
>>>> Ulf,
>>>> it, you
>>>> The
>>>> Wizards.
>>>> used the
>>>> Packaging as well.
>>>> discussion,
>>>> scott
>>>>>eclipse
>>>>>product
>>>>>we
>>>>>standard
>>>>>that
>>>>>And
>>>>>configure
>>>>>my
>>>>>in
>>et\
>>>>>tempAnt.xml
>>>>>What
>>>>>was
>>>>>for
>>>>>build
>>>>>it
>>>>>is
>>>>>interface
>>>>>and
>>>>>of
>>>>>the
>>>>>nasty.
>>>>>I
>>>>>this
>>>>>xdoclet
>>>>>and
>>>>>is
Re: the xdoclet integration needs serious re-factoring or at least enhancement [message #184942 is a reply to message #184783] Fri, 15 December 2006 06:46 Go to previous messageGo to next message
to answer your other question: No, I don't know anything about
xdoclet-1.2.1.jar missing.
WST without JBoss plugin worked for me (from Callisto). But I was alwasy
using xdoclet-1.2.3.
> anything
> I
> just
> somewhere,
> I
> it
> all?
> short-sighted.
>>Scott,
>>seems
>>The
>>> to
>>> work
>>> scripts
>>> for a while....
>>>> Ulf,
>>>> it, you
>>>> The
>>>> Wizards.
>>>> used the
>>>> Packaging as well.
>>>> discussion,
>>>> scott
>>>>>eclipse
>>>>>product
>>>>>we
>>>>>standard
>>>>>that
>>>>>And
>>>>>configure
>>>>>my
>>>>>in
>>et\
>>>>>tempAnt.xml
>>>>>What
>>>>>was
>>>>>for
>>>>>build
>>>>>it
>>>>>is
>>>>>interface
>>>>>and
>>>>>of
>>>>>the
>>>>>nasty.
>>>>>I
>>>>>this
>>>>>xdoclet
>>>>>and
>>>>>is
Re: the xdoclet integration needs serious re-factoring or at least enhancement [message #184998 is a reply to message #184942] Fri, 15 December 2006 09:50 Go to previous message
err... WTP of course, not WST
news:elu1o9$5rk$1@utils.eclipse.org...
>> anything
>> I
>> just
>> somewhere,
>> stuff. I
>> it
>> all?
>> short-sighted.
>>>Scott,
>>>seems
>>>use
>>>AppServer
>>>The
>>>> to
>>>> but
>>>> work
>>>> scripts
>>>> that
>>>> for a while....
>>>>> Ulf,
>>>>> it, you
>>>>> The
>>>>> Wizards.
>>>>> used the
>>>>> Packaging as well.
>>>>> discussion,
>>>>> scott
>>>>>>eclipse
>>>>>>product
>>>>>>we
>>>>>>standard
>>>>>>that
>>>>>>And
>>>>>>configure
>>>>>>my
>>>>>>is
>>>>>>in
>>>et\
>>>>>>tempAnt.xml
>>>>>>That
>>>>>>What
>>>>>>was
>>>>>>which
>>>>>>ok
>>>>>>for
>>>>>>build
>>>>>>it
>>>>>>is
>>>>>>interface
>>>>>>and
>>>>>>of
>>>>>>the
>>>>>>nasty.
>>>>>>I
>>>>>>wheel
>>>>>>(in
>>>>>>this
>>>>>>xdoclet
>>>>>>and
>>>>>>is
Previous Topic:Tomcat republishing does not work
Next Topic:problem debugging Tomcat application
Current Time: Sat Jul 19 04:52:21 EDT 2025
Powered by FUDForum. Page generated in 0.05908 seconds
