| ssh-only configuration with Plink [message #18449] | Tue, 29 January 2008 13:15  |  |
| Eclipse User  |  |  |  |  | Originally posted by: galstuk.rocketmail.com
 Is there a way to configure rse to use an ssh private/public key
 certificates (PuttyGen)?  It works beautifully on port 22 without the
 certificates, but my systems all require encrypted comms.  I'm looking for
 a way to configure RSE similar to CVS with plink for the ext ssh
 configuration.  I see where there are variables that can be built but have
 no doc on how to configure these for ssh via plink or something akin to
 plink.
 David Baker
| Re: ssh-only configuration with Plink [message #18457 is a reply to message #18449] | Fri, 01 February 2008 06:26  |  |
| Eclipse User  |  |  |  |  | Hi David,
 RSE uses its own internal SSH client, which won't connect
 to your plink server. But what you can do, is tell it
 where your private key(s) are located.
 Window > Preferences > General > Network Connections > SSH2
 Pressing F1 there will give you some info. Basically,
 enter an SSH Home Directory, where your private keys
 are stored. I'm typically using NTFS Encryption and
 permissions as an added security measure on that
 directory.
 In PuTTYGen, export your private key as an OpenSSH key.
 In Eclipse, import it on the Key Management Tab. If the
 private key is without passphrase, RSE will connect with
 a blank password which you can also store, so then RSE
 does not ask you any more.
 Martin Oberhuber, Senior Member of Technical Staff, Wind River
 Target Management Project Lead, DSDP PMC Member
 http://www.eclipse.org/dsdp/tm
 > for a way to configure RSE similar to CVS with plink for the ext ssh
 > have no doc on how to configure these for ssh via plink or something
 > akin to plink.
 > David Baker
| Re: ssh-only configuration with Plink [message #572122 is a reply to message #18449] | Fri, 01 February 2008 06:26  |  |
 directory.
 > akin to plink.
 > David Baker
FUDForum. Page generated in 2.74221 seconds
