Home » Eclipse Projects » Eclipse Platform » What is the rigth way of getting an ImageDescriptor?
What is the rigth way of getting an ImageDescriptor? [message #184568] Sun, 25 January 2004 11:51 Go to next message
Originally posted by: IanPLang.yahoo.com
I am new to Eclipse and am experimenting with RCP - very cool. Now that I
have done some work on menus and a view I want to get my applicaiton image
in the title bar. If I can load the image everthing is fine. The trouble
is I cannot seem to get an ImageDescrptor in a good way. At first I used
a hard coded path just to see if I could get images in the app's title bar
- worked fine. Then I looked around to find the right way to load them
and found an article "Using Images in the Eclipse UI". I decided that the
image registry would not be appropriate for these images since they will
be used once for the application's title bar. So I decided to use code
like this (as recomended by the article):
private static ImageDescriptor image;
static {
URL url = null;
try {
url = new URL(MyPlugin.getInstance().getDescriptor().getInstallURL(),
"images/my_action.gif");
} catch (MalformedURLException e) {
image = ImageDescriptor.createFromURL(url);
I looked at the documentation for the methods used and found that
Plugin.getDescriptor() is going to be depricated - so much for that.
Then I poked around the API docs and found
AbstractUIPlugin.imageDescriptorFromPlugin which seemed to fit the bill.
So I tried code like this:
ImageDescriptor descAppImage16 =
AbstractUIPlugin.imageDescriptorFromPlugin (MY_PLUGIN_ID,
"images/MyApp16.gif"); //$NON-NLS-1$
Where the images directory is under my plug-in's directory. It did not
work! I looked at the contents of the resulting URLImageDescriptor and
found its path was "/plugin/com.lang.app_0.1.0/images/MyApp16.gif". Which
is good except for the "0.1.0" stuck in there. I tried renaming my
plug-in's folder to add the "0.1.0" but that did not work either.
What is wrong with what I am doing? What is the right way?
IL
Re: What is the rigth way of getting an ImageDescriptor? [message #185418 is a reply to message #184568] Tue, 27 January 2004 09:27 Go to previous messageGo to next message
I found out what was wrong myself: When I saw the "_0.1.0" I stopped
reading. Closer inspection reveled my mistake. I had created a "icons"
directory on disk and was trying to load from a non existent "images"
directory - oops.
So I am assuming that AbstractUIPlugin.imageDescriptorFromPlugin is the
right way to go about loading images - unless someone here tells me
different.
IL
Ian Lang wrote:
<snip>
Re: What is the rigth way of getting an ImageDescriptor? [message #185774 is a reply to message #184568] Tue, 27 January 2004 17:03 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
You can continue to use the code from the article. If this API is
deprecated it will happen *after* the Eclipse 3.0 release. Even then,
it is likely it won't actually be removed for a long time (if ever).
Nearer to the Eclipse 3.0 release I will update the article with the
"official" recommended approach for 3.0.
> static {
> URL url = null;
> try {
> IL
Re: What is the rigth way of getting an ImageDescriptor? [message #185798 is a reply to message #185774] Tue, 27 January 2004 19:19 Go to previous message
Thanks for the info - I look forward to reading the update.
IL
Previous Topic:Eclipse 3.0 M6 Update Manager
Next Topic:[ANN] CodePro v2.3.2 Release - 425+ Audit Rules & Metrics
Current Time: Sat Jul 26 11:18:21 EDT 2025
Powered by FUDForum. Page generated in 0.24800 seconds
