Home » General (non-technical) » Eclipse Foundation » EClipse Help menu(Missing items)
EClipse Help menu [message #1845076] Wed, 06 October 2021 01:03 Go to next message
Dear Sir/Mrs.
I have iinstalled the Eclipse Version 2021-09(4.21.0).
The help menu does not include:
1. Check for update.
2. Install new software.
Yehuda
Re: EClipse Help menu [message #1845078 is a reply to message #1845076] Wed, 06 October 2021 02:48 Go to previous messageGo to next message
How did you install it? Where did you install it?
Re: EClipse Help menu [message #1845079 is a reply to message #1845078] Wed, 06 October 2021 02:55 Go to previous messageGo to next message
Dear Mr. Ed Merks.
I downloaded the latest Eclisped version from https://www.eclipse.org/downloads/.
I installed in the folder: /opt/eclipse-parallel
Yehuda
Re: EClipse Help menu [message #1845082 is a reply to message #1845076] Wed, 06 October 2021 03:40 Go to previous messageGo to next message
Have a look at the log to maybe get hints about what goes wrong: https://wiki.eclipse.org/FAQ_Where_can_I_find_that_elusive_.log_file%3F
Re: EClipse Help menu [message #1845083 is a reply to message #1845082] Wed, 06 October 2021 03:59 Go to previous message
I assume you are on Linux and that you used the installer. To install to /opt you probably use "su" to temporarily have write permission there. But the installer by default uses a shared bundle pool and by default that's in your home folder in ~/.p2/pool. So you probably ended up with a strange combination of an installation that is read only but is using a shared bundle pool that is not read only. Please read the details here and decide if you want to have a shared read-only installation or if you want to have your own personal installation:
https://www.eclipse.org/setups/installer/question/
Previous Topic:Donation is not accepted through Paypal.
Next Topic:Bad signature for eclipse-4.21-SUMSSHA512
Current Time: Sun Jul 27 02:00:17 EDT 2025
Powered by FUDForum. Page generated in 0.25517 seconds
