Re: Fail- Code generation for ROS2 [message #1847544 is a reply to message #1847472] |
Sun, 31 October 2021 17:56  |
Hi Ansgar,
I confirm : example dummy_robot work correctly.
Reverse Code C++ Fail
However in a new project the papyrus for robotics, I have executed the command: ros2 launch dummy_robot_bringup dummy_robot_bringup.launch.py (code : https://github.com/ros2/demos/tree/master/dummy_robot)
I have executed Reverse ROS Nodes Running from running system , the example dummy_robot no work correctly (You can check it yourself).
Could you update this example to work correctly with Reverse Code C++ from running system?
Luis.
FUDForum. Page generated in 0.06168 seconds
