Home » Language IDEs » Java Development Tools (JDT) » Doc about EclipseCompiler for JSR 199?(How can I set warning and related options using the JavaCompiler interface?)
Doc about EclipseCompiler for JSR 199? [message #1839111] Sun, 14 March 2021 13:55 Go to next message
I have been successfully using EclipseCompiler as an instance of JavaCompiler, to compile Java classes in memory.
Here is a sample code.
JavaCompiler compiler = new EclipseCompiler();
StandardJavaFileManager fileManager = compiler.getStandardFileManager(fileDiagnostics, Locale.US, StandardCharsets.UTF_8);
fileManager.setLocationFromPaths(StandardLocation.ANNOTATION_PROCESSOR_PATH, ImmutableList.of());
fileManager.setLocationFromPaths(StandardLocation.CLASS_PATH, classPath);
fileManager.setLocationFromPaths(StandardLocation.CLASS_OUTPUT, ImmutableSet.of(outputDirectory));
StringWriter compilationOutputReceiver = new StringWriter();
boolean compiled = compiler.getTask(compilationOutputReceiver, fileManager, compilerDiagnostics, ImmutableList.of(), null, fileManager.getJavaFileObjectsFromPaths(sourcePaths)).call();
String compilationOutput = compilationOutputReceiver.toString();
I use org.eclipse.jdt:ecj:3.24.0, which defines org.eclipse.jdt.internal.compiler.tool.EclipseCompiler.
Can I find some documentation about this implementation of JSR 199? (I have read Compiling Java code but I do not think it is related to what I try to do as the code I want to compile is not in an Eclipse workspace and I am not developing an Eclipse plug-in.)
In particular, I wonder how to pass this compiler an equivalent of the option -properties <file> that can be used with the batch compiler. Other things I wonder about are what Eclipse will give me (by contract) as file manager diagnostics; as compile task diagnostics; and as mere output (compilationOutput in my code sample).
Is there some documentation about all this somewhere? Or should I use another jar for accessing Eclipse's implementation of JSR 199? (I am also a bit puzzled by the EclipseCompiler being in an "internal" package.)
[Updated on: Sun, 14 March 2021 13:57] by Moderator
Re: Doc about EclipseCompiler for JSR 199? [message #1844887 is a reply to message #1839111] Tue, 28 September 2021 16:15 Go to previous messageGo to next message
Hello! Have you received any response to this?
I am trying to use the eclipse java compiler to compile our code in batch, but am struggling to find any documentation on it.
If you have found a solution for that, I'd love to hear what you did.
Thanks!
Re: Doc about EclipseCompiler for JSR 199? [message #1844920 is a reply to message #1844887] Wed, 29 September 2021 12:19 Go to previous message
I'd love to have a positive answer. Unfortunately, I am still at the same point, no clue about how to use this compiler apart from trial and error.
Previous Topic:Java Compiler Error
Next Topic:New and already an error
Current Time: Sun Jul 27 09:45:18 EDT 2025
Powered by FUDForum. Page generated in 0.03109 seconds
