Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » There is "-1.#IND" value when running app
There is "-1.#IND" value when running app [message #1844892] Wed, 29 September 2021 01:52 Go to next message
hi, I'm a new member here.
I'm having a problem when I try to run the forte, there is a "-1.#IND" value in data input and data output of "IntegratedSum_MixTank" BFB that I created. I've also attached the picture below.
please kindly help me to solve this kind of problem
Thank you in advance
  • Attachment: -1.#IND.PNG
    (Size: 92.74KB, Downloaded 88 times)
Re: There is "-1.#IND" value when running app [message #1844907 is a reply to message #1844892] Wed, 29 September 2021 09:31 Go to previous message
Welcome to Eclipse 4diac. Happy to have you here. May I ask which data type your input UD1 and you output sum7 has?
Alois
Previous Topic:Problem with configure in CMake
Next Topic:Install new FB for a machine (NOJA POWER)
Current Time: Fri Aug 01 01:00:08 EDT 2025
Powered by FUDForum. Page generated in 0.38657 seconds
