Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Problem with configure in CMake(Problem with configure in CMake)
Problem with configure in CMake [message #1844649] Mon, 20 September 2021 07:30 Go to next message
I have a configuration problem in CMake. He gets such an error in response - i add in attachment. What is caused by how can it be solved?
Best regards
Michal
Re: Problem with configure in CMake [message #1844653 is a reply to message #1844649] Mon, 20 September 2021 08:25 Go to previous messageGo to next message
which C++ compiler have you installed on your machine?
Alois
Re: Problem with configure in CMake [message #1844654 is a reply to message #1844653] Mon, 20 September 2021 08:51 Go to previous messageGo to next message
if VS 2022 is installed on your machine, then the compilers are not visible on the PATH.
Try starting CMake via the Visual Studio Native Tools Command Prompt.
Martin
Re: Problem with configure in CMake [message #1844737 is a reply to message #1844654] Thu, 23 September 2021 10:37 Go to previous messageGo to next message
I use MinGW-w64 compilator. My hardware supplier using 4diac but I need to give it new functionality, I need to add modbus library
[Updated on: Thu, 23 September 2021 10:38] by Moderator
Re: Problem with configure in CMake [message #1844742 is a reply to message #1844737] Thu, 23 September 2021 12:44 Go to previous messageGo to next message
If you use MinGW compiler you must not select a visual studio project in cmake but either unix make files or I think there is also a mingw project. The latter I have never tried. Please have a look in our docs on how to build 4diac FORTE with mingw.
Re: Problem with configure in CMake [message #1844822 is a reply to message #1844742] Mon, 27 September 2021 04:49 Go to previous messageGo to next message
I change my compilator and now I have this problem:
CMake Deprecation Warning at CMakeLists.txt:17 (CMAKE_MINIMUM_REQUIRED):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
Building executable
CMake Error at CMakeLists.txt:252 (message):
No valid architecture chosen! Please check FORTE_ARCHITECTURE.
Re: Problem with configure in CMake [message #1844829 is a reply to message #1844822] Mon, 27 September 2021 07:52 Go to previous messageGo to next message
You have a rather old CMake version. I would strongly recommend to update to a newer CMake version. We haven't tested it with older versions.
The last error tells you that you need to configure your 4diac FORTE build. This means selecting the modules you like to have included and at least specify for which architecture you want to build. For windows and mingw32 you need to select win32.
Re: Problem with configure in CMake [message #1844864 is a reply to message #1844829] Tue, 28 September 2021 05:32 Go to previous messageGo to next message
I have the latest version of CMAKE but I still get this error. The rest of the errors have been fixed I only have this one left. Thank you for your help
Re: Problem with configure in CMake [message #1844888 is a reply to message #1844864] Tue, 28 September 2021 17:30 Go to previous message
Oh then I missunderstood the message and we may have to look into our CMake setup. great that it works now for you.
Previous Topic:External event queue is full, external event dropped!
Next Topic:There is "-1.#IND" value when running app
Current Time: Wed Jul 30 08:32:01 EDT 2025
Powered by FUDForum. Page generated in 0.03808 seconds
