Home » Language IDEs » ServerTools (WTP) » ejbdoclet out-of-memory
ejbdoclet out-of-memory [message #184474] Tue, 12 December 2006 09:33 Go to next message
I am trying to convert my J2EE application to WTP but xdoclet is running
out-of-memory. Increasing the heapsize and MaxPermSize has no effect.
I was using the JBoss plugin so far. That plugin is generating an ant script
to run xdoclet. That way I could simply run the ant script from "external
tools" in a separate VM and assign as much memory as I wanted.
Any way to do that in WTP?
/ulf
Re: ejbdoclet out-of-memory [message #184483 is a reply to message #184474] Tue, 12 December 2006 10:13 Go to previous messageGo to next message
just noticed that xdoclet is executed in a separate VM anyway. Is there any
way to define the memory for that vm?
"Ulf Gohde" <ulf.gohde@banctec.co.uk> wrote in message
news:elmed5$udj$1@utils.eclipse.org...
> script to run xdoclet. That way I could simply run the ant script from
> "external tools" in a separate VM and assign as much memory as I wanted.
> /ulf
Re: ejbdoclet out-of-memory [message #184490 is a reply to message #184483] Tue, 12 December 2006 10:26 Go to previous message
I found a workaround. It works when I execute
<workspacedir> \.metadata\.plugins\org.eclipse.jst.j2ee.ejb.annotations.xdo clet\tempAnt.xml
from "external tools" in a separate VM and assigning memory via -Xmx to that
VM
news:elmgoj$ho5$1@utils.eclipse.org...
> any way to define the memory for that vm?
>> /ulf
Previous Topic:Has anyone successfully deployed a WTP ear to Weblogic 8.1?
Next Topic:xmlns in xhtml document
Current Time: Fri Jul 18 12:57:35 EDT 2025
Powered by FUDForum. Page generated in 0.04670 seconds
