Success ... but more questions [message #1844469] |
Tue, 14 September 2021 11:33  |
OK, it complied, linked and runs...
10:08:18 **** Incremental Build of configuration Debug for project BASE_CrossGCC ****
make all
Building file: ../src/BASE_CrossGCC.cpp
Invoking: Cross G++ Compiler
arm-linux-gnueabihf-g++ -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"src/BASE_CrossGCC.d" -MT"src/BASE_CrossGCC.o" -o "src/BASE_CrossGCC.o" "../src/BASE_CrossGCC.cpp"
Finished building: ../src/BASE_CrossGCC.cpp
Building target: BASE_CrossGCC
Invoking: Cross G++ Linker
arm-linux-gnueabihf-g++ -o "BASE_CrossGCC" ./src/BASE_CrossGCC.o
Finished building target: BASE_CrossGCC
10:08:20 Build Finished. 0 errors, 0 warnings. (took 1s.501ms)
1. Should I be able to "find" -name "*BASE*"
somewhere on my RPi?
2.But it miraculously "runs" AFTER I implement "Application" " Remote File Path"
... any path, even "/" empty .
So what gives ?
Re: Success ... but more questions [message #1844481 is a reply to message #1844475] |
Tue, 14 September 2021 19:49  |
Eugene Tarassov wrote on Tue, 14 September 2021 17:04If you enter both Local and Remote file path, TCF will copy (download) the file from Local to Remote every time you launch the debug session.
> Should I be able to "find" -name "*BASE*" somewhere on my RPi?
No, because you entered "test" as the Remote file name, not "*BASE*".
I'm not sure what you mean. Remote file path cannot be a directory, it should be a file.
OK, let;s recap.
There are these entries
1. local "file path" ( Debug/BASE_CrossGCC) which is hardly a "path" because it includes the actual file name.
But that works.
2. Remote "file path" which makes no sense because just "/" will enable "run" button and it will execute on the RPi.
3. Then there is a "remote directory" which has option of "default" , and same as above item 2 - the app runs on RPi with default.
The cross linker clearly identifies the object file and I cannot "find" in on the RPi.
Now to make it more interesting - in "TCF debug" configuration I get "TCF process console " and so far I have no idea where does it come from - it is "automatic" . It does "print" all stuff coded ....
And I believe there is "by the way" a note which said that this "TCF process" has to run/ be implemented on the target.
All this makes implementing TCF such hit and miss, but I still believe resolving all of these by giving reasons why - would make Eclipse and TCF a great tool to make Raspberry really shine.
Funny part - this has all been discussed before , but my personal RAM is not that great anymore...
yes, I kept notes ....periodically destroyed by new and "improved " OS
Cheers
FUDForum. Page generated in 0.28717 seconds
