Home » Language IDEs » Java Development Tools (JDT) » Yet another update surprise... Eclipse 2021-06 doesn't start up anymore... :-(
Yet another update surprise... Eclipse 2021-06 doesn't start up anymore... :-( [message #1844413] Mon, 13 September 2021 08:32 Go to next message
After I had Eclipse update itself (from 2020-12 to 2021-06) I can now not open the eGit "Repositories View" any longer. :-(
Since access to Git is a requirement I now need to retrograde. Terrific!
The upgrade itself went smoothly, i.e. no error message or warnings or anything suspicious...
Any idea anyone, what could cause this? Any fix/workaround?
This is the error I am getting:
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.egit.ui" was unable to instantiate class "org.eclipse.egit.ui.internal.repository.RepositoriesView".
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:212)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:206)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:920)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:246)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:63)
	at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:61)
	at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:104)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:304)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:342)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:564)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:999)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:964)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:140)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:405)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:332)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:202)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:999)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:544)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:528)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:73)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:765)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:730)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:714)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1209)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:114)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:677)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:71)
	at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:150)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:673)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:51)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:64)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:666)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1083)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
Caused by: java.lang.reflect.InvocationTargetException
	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
	at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:500)
	at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:481)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:204)
	... 112 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.egit.core.RepositoryUtil
	at org.eclipse.egit.ui.internal.repository.RepositoriesView.<init>(RepositoriesView.java:306)
	... 118 more
[Updated on: Mon, 13 September 2021 08:34] by Moderator
Re: Yet another update surprise... Eclipse 2021-06 doesn't start up anymore... :-( [message #1844415 is a reply to message #1844413] Mon, 13 September 2021 08:56 Go to previous messageGo to next message
I suspect that there i a more revealing problem further down the stack trace.
My best guess is that there is a Java version incompatibility. Were you using Java >= 11 before you upgraded? How do you specify your Java version? Perhaps a manual Eclipse.ini edit got reverted.
Ed Willink
Re: Yet another update surprise... Eclipse 2021-06 doesn't start up anymore... :-( [message #1844439 is a reply to message #1844415] Tue, 14 September 2021 03:01 Go to previous messageGo to next message
Hi Ed
yes, I was apparently using Java 14 (the one that had come with the eclipse installation).
I compared the eclipse.ini of my last backup with the broken installation and interestingly they are absolute identical.
The VM plugin directory (first two lines) exists in both.
-vm
plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_14.0.2.v20200815-0932/jre/bin
-startup
plugins/org.eclipse.equinox.launcher_1.6.0.v20200915-1508.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.2.0.v20200915-1442
-product
org.eclipse.epp.package.jee.product
-showsplash
org.eclipse.epp.package.common
--launcher.defaultAction
openFile
openFile
--launcher.appendVmargs
-vmargs
-Xverify:none
-Dcom.ibm.icu.util.TimeZone.DefaultTimeZoneType=ICU
-javaagent:U:\eclipse\eclipse-jee\lombok.jar
-Dosgi.requiredJavaVersion=11
-Dosgi.instance.area.default=@user.home/eclipse-workspace
-Dsun.java.command=Eclipse
-XX:+UseG1GC
-XX:+UseStringDeduplication
--add-modules=ALL-SYSTEM
-Dosgi.dataAreaRequiresExplicitInit=true
-Xms512m
-Xmx5120m
-Dsun.lang.ClassLoader.allowArraySyntax=true
and in fact the content of ...\plugins\org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_14.0.2.v20200815-0932 is bitwise identical (checked with a compare tool).
I have kept the broken version and restored my working copy, so if anyone needs info or diffs of the two I can provide that.
BTW: small correction of my initial append: I upgraded from 2021-03 (not 2020-12) to 2021-06.
[Updated on: Tue, 14 September 2021 03:22] by Moderator
Re: Yet another update surprise... Eclipse 2021-06 doesn't start up anymore... :-( [message #1844446 is a reply to message #1844439] Tue, 14 September 2021 05:44 Go to previous messageGo to next message
Ok, sorry, you've exhausted my simplistic helpfulness. I do recall discussion of upgrade problems on cross-project-dev, but did not pay much attention since in 15 years I have never upgraded an Eclipse installation. It's one of those areas where I am encouraged in my current practices by problems that do not affect me.
Ouch! Do I read your comment as suggesting that you upgraded from a built-in Java 14 to another built-in Java 14? Built-in Java is very new technology for Eclipse. I can see an opportunity for filesystem/registry confusion.
Perhaps a better informed committer may pick up the thread.
Ed Willink
Re: Yet another update surprise... Eclipse 2021-06 doesn't start up anymore... :-( [message #1845108 is a reply to message #1844446] Thu, 07 October 2021 05:14 Go to previous message
In case anybody else is stumbling over this thread: My old, restored version v21-03 at some point decided to upgrade itself to v21-09 (instead of v21-06 as before), only this time eGit kept working after the upgrade. No more missing classes!
So - issue apparently resolved with v21-09!
[Updated on: Thu, 07 October 2021 05:16] by Moderator
Previous Topic:New Comer Alert!
Next Topic:Unable to read http://download.eclipse.org/buildship/updates/e46/releases/3.x/compositeContent.xml.
Current Time: Fri Jul 25 21:49:07 EDT 2025
Powered by FUDForum. Page generated in 0.03754 seconds
