Home » Eclipse Projects » Standard Widget Toolkit (SWT) » bind system.out stream to SWT text widget
bind system.out stream to SWT text widget [message #454473] Thu, 21 April 2005 13:38 Go to next message
I'm trying to figure out how I can bind the system.out stream to a swt
text widget. I've figured out that I can use System.setOut() to redirect
the stream. But now I'm stuck at trying to get it connected to a text
widget. Does anyone have any hints or code examples?!
Re: bind system.out stream to SWT text widget [message #454474 is a reply to message #454473] Thu, 21 April 2005 13:54 Go to previous messageGo to next message
Eclipse does this kind of thing when you launch Java applications, so
you could poke around in the JDT plugins.
Charlie
Duncan Krebs wrote:
Re: bind system.out stream to SWT text widget [message #454477 is a reply to message #454474] Thu, 21 April 2005 17:47 Go to previous messageGo to next message
Charlie thanks for the idea. I figured out it involves using PipedStreams
and multiple threads.
Re: bind system.out stream to SWT text widget [message #1844167 is a reply to message #454477] Fri, 03 September 2021 16:24 Go to previous messageGo to next message
Is it possible to describe or share code for how you achieved this ?
Re: bind system.out stream to SWT text widget [message #1844245 is a reply to message #1844167] Tue, 07 September 2021 01:42 Go to previous message
This is very easy to do!
First extend PrintStream as follows;
public class YourPrintStream extends PrintStream {
and implement the following methods inside this class to display your message on your SWT widget. That is, implement write() to display on your widget.
public void write(int b) {
public void write(byte[] buf, int off, int len) {
public void close() {
Finally in the beginning, instantiate this extended class and set for out and err as follows;
YourPrintStream f3 = new YourPrintStream(,,,);
System.setOut(f3);
System.setErr(f3);
Previous Topic:Breaking Change in GTK-API for x86_64 (v3.116.100) ?
Next Topic:Enable finish button on "Export" wizard
Current Time: Fri Aug 29 20:04:44 EDT 2025
Powered by FUDForum. Page generated in 0.03497 seconds
