Home » Modeling » EMF » Invoking XSDExporter (ModelConverter) programmatically (CI/CD for EMF functionality)
Invoking XSDExporter (ModelConverter) programmatically [message #1844121] Wed, 01 September 2021 20:52 Go to next message
The XSDExporter is a subclass of ModelExporter and ModelConverter.
Provided the corresponding bundles are installed into an Eclipse instance, is there an ant task or eclipse application to invoke this functionality? Will this invocation require the workbench and GUI to be running, or can this be run headless.
If there is not, how could such functionality be implemented?
Re: Invoking XSDExporter (ModelConverter) programmatically [message #1844127 is a reply to message #1844121] Thu, 02 September 2021 00:53 Go to previous message
No, there are no ant tasks or applications for exporting. They should be implemented in much the same way to function headless. You could look at org.eclipse.xsd.ecore.importer.XSDImporterApplication as a similar example.
Previous Topic:Java.lang.RuntimeException: Cannot create a resource for 'xxxx'; a registered resource
Next Topic:Ecore for mapping metamodel
Current Time: Wed Jul 30 21:26:41 EDT 2025
Powered by FUDForum. Page generated in 0.03656 seconds
